Hello
I have been talking to different tuners here in Japan and one of them suggested a 2.4 litre upgrade kit for my RB20 Det.
Are these worth it or is it better to build up my 20 with the normal 2 litre? My goal is 400 hp for the street.
I am not going RB25 because of the costs of registering the car, paying the extra to the government for the engine change and the doubling of the yearly road tax fees here which is expensive.
400hp for the street is impossible on a RB20DET. It will be a lag fest.
Since you are in Japan I am assuming you can read Japanese? Go pick up an issue of Hyper-rev regarding the GTS-t, it will say the exact same thing I am about to tell you.
You have three options:
1. 350hp, responsive for street
2. 400hp, lag monster
3. increase displacement
The only real problem I see is that most of the 2.4 litre upgrade kits are no longer available (HKS, Tomei). What exactly was he suggesting you use?
Edited by Matvei27
should be able to make 400hp easy without going built motor and being in Japan when it goes bang it'll still be cheap to replace
He can do it but it won't be fun to drive on the street, and he said he wanted it for the street...so probably not a great idea.
If he doesn't want to pay for a 3 number plate, which the RB25 would require, the RB24 is really the best option he can get.
The problem is availability since the majority of these kits are discontinued.
Edited by Matvei27
There is a state side company that sells kits for it. Here there are still the parts needed for the conversion available.
Which, specifically? The Tomei kit is discontinued, the HKS kit is discontinued...Testarossa still does RB23 and RB24 in Japan but the quality is a bit sketchy from what I have heard.
How does the higher registration fees compare to building a stroker?
Give me some numbers....
This isn't Australia. The RB22 and RB24 were popular in Japan for a very good reason.
Don't have the prices in front of me right now. If I remember correctly:
To have a shop put it in is about 500-1000 dollars ( quality of work and shop varies) Most good shops here are expensive. Have to find a decent RB25 and make sure it works. About 800-1000 dollars. Price of whatever after market turbos, etc. Price? Registration between 500-1000 dollars(unless I was told wrong.) Yearly road tax, about 200 dollars a year. We have to pay a reregistration fee every two years also which will go up in price with the bigger engine. Its 800 dollars for me with the rb20.
Are you 100 percent sure Tomei still sells the pistons? Because their website says 生産終了
http://www.tomei-p.co.jp/_2003web-catalogue/053_RB20_piston.html
If they actually still make them I'll go buy a 2.2 kit right now...
Edited by Matvei27
Unless I was lied to, they still have it.
Yahoo action Japan carries it also.
The listings on Yahoo don't mean anything, if you read them they say to confirm stock with the manufacturer, and often times they are outdated listings.
Unless Tomei specifically told you they have them (despite the website saying they don't make them anymore), then they probably don't.
I'll call them on Monday.
Edited by Matvei27
A good RB25DET neo would be cheaper than building a stroker...which leaves room for paying extra at renewal time and you get the extra torque from day one.
Can you buy a 2.5L R32 and put the turbo gear in that ? Or just buy a GTS25T.
The biggest problem for an RB20 block is the bore size , this limits the chamber diameter and that limits the valve size . RB20 valve sizes are inadequate for 2.3-2.4 litres and there is nothing economically viable you can do about it . Painted into a corner you can't get out of , this is literally why a big bore (86mm) RB24 or RB25 will always make better power than a stroked RB20 . BTW there was actually a big bore RB24 which I think had the RB20 stroke crank with slightly longer rods . It may have been a pov pak third world carby option .
A .
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
