So ive noticecd some mention of fire extinguishers in the car in one of the posts?
Is this compulsory? or are you talking that IF you have a fire extinguisher, it has to be securely fastened?
thanks
thanks
Compulsory
Will not pass scrutineering without one
So this is just a Skylines Australis requirement? I was at a wakefiled speed off the streets track day recently with no requirement for an extinguisher?
Where do i get one from (cheap and within 3 weeks)?
Thanks
Thanks
Most days with timing require fire extinguishers and is a requirement from our insurance
In my opinion it's piece of mind having one, could be what's stops your car burning to the ground
Supercheap auto, autobarn etc stock them on the shelf, usually only $20ish
Just make sure it's the type with metal strap and bracket and 1kg minimum
  • Like 1
ok, thanks for your help. Nice to hear they dont cost too much
I got mine from the local Big W. It's the bracket you should be more worried about (unless you're handy with metal).
I got one of those 'evok3d' ones, bolt in, works great.
I promice asking the boss tomorrow about if im able to have day off, tax has cleared so entry can be paid, and maybe some coil overs and tires for the 32 ;)
  • Like 1
Yeah ive had a bit of a look and actually the cheapest ones seem to be at Bunnings and the one ive gone for is from Officeworks! Didnt check Big W but too late now.
See you guys in a few weeks :cheers:
Just to be clear, your car WILL be scruitinered.
That means, someone will look over it for leaks, loose items in the cabin/boot, sufficient tyre tread, brake operation, battery secured (big one! With metal, not zipties!), seat belt condition and operation.
If you are unsure about any of these things, please ask, and/or get it sorted before turning up on the day :)
  • Like 1
Paid in full. Sorry for late pay but have confirmed i am free that day.
On another note will my car fail for having rat crap in it, apparently parking your race car on a property is not the best storage :glare:
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
