So ive noticecd some mention of fire extinguishers in the car in one of the posts?
Is this compulsory? or are you talking that IF you have a fire extinguisher, it has to be securely fastened?
thanks
thanks
Compulsory
Will not pass scrutineering without one
So this is just a Skylines Australis requirement? I was at a wakefiled speed off the streets track day recently with no requirement for an extinguisher?
Where do i get one from (cheap and within 3 weeks)?
Thanks
Thanks
Most days with timing require fire extinguishers and is a requirement from our insurance
In my opinion it's piece of mind having one, could be what's stops your car burning to the ground
Supercheap auto, autobarn etc stock them on the shelf, usually only $20ish
Just make sure it's the type with metal strap and bracket and 1kg minimum
  • Like 1
ok, thanks for your help. Nice to hear they dont cost too much
I got mine from the local Big W. It's the bracket you should be more worried about (unless you're handy with metal).
I got one of those 'evok3d' ones, bolt in, works great.
I promice asking the boss tomorrow about if im able to have day off, tax has cleared so entry can be paid, and maybe some coil overs and tires for the 32 ;)
  • Like 1
Yeah ive had a bit of a look and actually the cheapest ones seem to be at Bunnings and the one ive gone for is from Officeworks! Didnt check Big W but too late now.
See you guys in a few weeks :cheers:
Just to be clear, your car WILL be scruitinered.
That means, someone will look over it for leaks, loose items in the cabin/boot, sufficient tyre tread, brake operation, battery secured (big one! With metal, not zipties!), seat belt condition and operation.
If you are unsure about any of these things, please ask, and/or get it sorted before turning up on the day :)
  • Like 1
Paid in full. Sorry for late pay but have confirmed i am free that day.
On another note will my car fail for having rat crap in it, apparently parking your race car on a property is not the best storage :glare:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
