Turn the wick up a bit further and there is 500. At 25.5 psi it isn't "nosing over" as such. Give it 30-32 and it bust through that 500 kW mark.
You are such a boy !!! lol
When is the car finished, box in and going yet ?
Got a video of the box going from N to 1 to 2 tonight. Quick dyno session for health/tune reasons then pickup
Well done for sticking it out pete, awesome result and a credit to jez. man i can only hope im still into these cars as much as you are by the time im your age. I would love to see you flying down the road in this it would make my day.
Just look at the roof there will be a wheel chair strapped on it, but a red one, very fast :)
^^^ LOL @ the CRD fan boii! You've done nothing but defend them all along and are still trying to!
The result is night and day and goes to show who does the hard yards to get their customers the results they paid for! GTFO out of this thread!
you've done nothing but bash them like a complete twat.
I just don't sit behind a keyboard being high and mighty. Many people had differing opinions of what could of been the issues, none of which we would of known until the car was looked at by Jez. Now we know.
Not once have I defended them, just put another option of opinion, un like you, who clearly just want to voice your blind one sided opinion on the internet.
If you still think any business is successful because of poor customer service or unhappy customers, you're delusional.
I'm happy that Pete's car is doing what he wanted it to do now.
And Pete, not once have I said you've bashed them, it's people like Mick who have done that.
Mate, I know you have not said I bash them, it is over with, lets move on:/
As soon as I get it I will see if I can warm those tyres up :)
Don't bother mate, this 'garage wars' shit has always happened, not worth giving it fuel.
Might be asking you the same question Pete if you launch with that much mumbo. Not sure what the Getrag is good for.
Guess I will have to find out, if it goes tits up I can borrow Pauls 88 , until mine gets here:/
They seem to hold the power quite well... That torque though... Not sure.
Damn Pete, should have kept to a 2.6L... Pfft!
The way it was, I was never worried about the box, I will have to drive it for a while and get the feeling, hope I make it home, I know I will not be able to help myself ,lol
Won't be revving it to 7k and dropping the clutch I don't reckon.
You just never know, but I will get a little movement first before letting it go, smokem :devil:
haha, I will work my way up and see how it goes, just want to finally feel it pulling hard :whistling:
theres no war going on here, just facts and back to back comparison on the same dyno from one person working on it to the next
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
