Yeah basically as the title has described.
Revs up
Decreases, Sometimes holds at 1100rpm momentarily and drops back to normal idle
Other times drops back to normal idle no worries
Such a weird little sticky point Any ideas? Anyone seen this before?.
Video for more clarification. Cheers
https://www.sau.com.au/forums/topic/455468-sticky-idle-rb25det/
I have the stock plms data cable + datascan. A while ago it threw fault code 17 tcs/acs/slip. Dont know if that had anything to do with it though. I cleared the ecu. Turned the car on and off and that fault code had never shown up again and the idle remained sticky.
tonnes of people keep directing me to clean the idle air control valve so i guess that is the goes.
any further help is appreciated though :)
Why does the tacho needle flicker a bit?
Is it really an issue?
It looks to me like its just a decel fuel cut issue, like sometimes the decel fuel cut is deactivating at different times or something. I found a similar thing happen when pulling up to a set of lights (not sure if it was on the Power FC or stock ECU). It would idle a bit higher until the car speed decreased to zero then went back to normal idle
I have exactly the same issue. When stopping revs will sit at 1000 or so rpms and then drop to normal, it's way worse when cold.
I've cleaned aac, checked ignition bits, looked for leaks many times and I have no idea where to go next. Could the aac valve be slow or something and need replacing? I have a small missfire on idle too which is possibly connected.
25de
Do the basic stuff first.
Clean the IAC as told.
Then if that doesn't work its time for a thread with videos etc. Not now.
Well the thread seem to net a bit more info and help me out a bit, Looks like others have come forward with some constructive criticism also. I understand you dont want forum flood all the time. But hey. It might help someone
It'd have to be an issue. Its annoying as f**k pulling up at the lights and having your rpm tacho do all weird shit and the car rev funnily when all youve done is press the clutch in and come to a stop.. and its climbed up to 1100 and back down to 850 for no reason.
Well it gets to me severely anyway. Also its alot worse on cold. Cold reversing out of my chicane like driveway clutching in and out has the revs sticking and dropping alot
25de
Ive been busy with work but im cleaning my iacv and a couple other checks this weekend ill let you know what happens for me
yes yes yes yes so much worse on cold..
Points more towards the iacv.
I appreciate all the brainstorming.
Im yet to feel a misfire in mine though. illl keep you posted
It doesnt really seem like a dirty AAC because it doesnt do it all the time (but anything is possible)
Is it just a standard ECU or has it got an aftermarket or piggyback unit fitted?
Is there anything that might be causing the problem that you arent realising, for example clutch in, in neutral and so on?
Is your throttle cable too tight? Or is something holding it ever so slightly off being fully closed?
Trying to think of an electronic reason, but it really has to be the ECU telling the AAC to hold the car at 1100rpm momentarily
Will keep having a think about this one
This weekend when i clean the aac will be the first teller for me and that will cross some stuff off the list for us both
Standard ECU, no piggybacks of any sort on the car
If the throttle cable was too tight itd be a permanent thing in my mind. Cable tension cant waft in and out like a saggy ballsack
Everything about the throttle body seems perfect to me.
It has to be an electrical issue between the ECU and the AAC haha. Fingers crossed anyway lol. Time will tell
I can gurantee you its not the throttle cable sticking or anything mechanical like that. That's the Typical ECU Trim/adjust computer stuff it does.
Something is causing your RPMs to stay a bit higher than what is expected, then the ECU goes oh shit thats too high for this amount of idle throttle it and dips it. Happens to my R33 as well. Here are some possible things you can look into that haven't been mentioned yet that have made my skyline exhibit these symptoms.
1 .AAC Valve Screw - Maybe the screw on the AAC vavle is a bit to high. Turn it clockwise maybe 1/4 of a rotation, so about 90 degrees, and see if that has any impact. IF not try do another 90 degrees to a full 180 and see how that has affected it. I wouldn't go past a full 360 turn if its not fixing the issue. Remember your stock position.
2 .High fuel pressure and any fuel pump wiring changes - Check your fuel pressure. When I changed my fuel pump and did a fuel pump rewire my idle RPMs were higher than they were before this until the ECU auto adjusted. but I noticed when stopping at lights the RPM would hold 1300ish just like yours before the ECU autocorrected. It seemed the car wanted to lurch and stay in higher RPMs instead of mellowing out. It would drop to 800ish and you had to just breathe on the thorrtle and it would rise to 1300 again, then dip, etc. Had to adjust AAC valve.
3. Something like Air condition running, power steering pump asking for juice, light, amp, a electrical drain on the alternator etc causing the ECU to want to raise the revs.
4. Timing not set properly, too high - Having the timing too high can cause this issue as well. Is your CAS adjusted about in the middle? See a lot of R34s with the CAS fully advanced.
Thats all I can think of right now
Edited by sonicz
^^ This is a common one I see.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
