hey guys,
i was jus drivin my R33 gts-t an gave it about 3/4 throttle in 4th gear an all of a sudden it didnt want 2 go an my exaust was blowing out more smoke then 4th of july.........i stoped an popped the bonnet an there was oil all over the top of my motor coming out of the intake pipe...yeah i got the pipe plugged up no BOV..... so i liet it kewl off 4 a minute an then started it again it started fine but soon as i touch the throttle it blows out S**T loads of smoke.....was only runnin on 10psi.....just want 2 get sum idea of wat u guys think im up 4....an wat sort off $$ its gonna b thanx.....
https://www.sau.com.au/forums/topic/45583-i-think-my-motor-is-fked/
  • Replies 130
thanx guys......
wat sort of $$ do u reakon ill b looking at 2 get it rebuilt.......????? an should i jus wait a while an get forgies chuked in while im at it..???
thanx help appreciated...
Where abouts do you live? best to take it somewhere asap and get a leak down test and it will tell you if it is the ringland, if it is yeah your probably best to chuck forgies in as the price of them these days is really not to bad, I've got a great mechanic/engine buildre but he's at Katoomba
um i was gonna try 2 drive it but soon as i gave it sum gas 2 get going it jus blew like so much smoke out i wasnt funny i figured i was best left off......
an i dont know if turbo is blown or not..im gonn pull it off in the mornin an c.....how can ya tell by lookin at it.......an i think it is my turbo cause the cooler is filled with oil......
well if it is blowby coming from the PCV valve in the rocker cover then it would be going into the intake anyway (black pipe crossing the covers ontop of engine) ... so that can explain oil in the cooler too! take the pipe off the top of the engine and see if there is wet oil in there- a healthy engine shouldn't have heaps of oil in the pipe! if it runs out of that then it's ring lands if not then the turbo is gone!
or you can get a leak down tester from autoone or something and test it that way. it will have instructions with it!
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
