My 32 gtr has a Nistune running 310rwkw. It has e85 1000cc injectors hks gtss turbos dumps exhaust.. from what I have read I have now maxed out my afm. I was thinking of buying the nismo afm and getting a haltech ecu. Is this a good option or do I just need to upgrade my afm?
Tuner can tell you.
Once you know, get rid of AFM and go MAP.( adaptronic or haltech plug in )
That said, you can still go beyond the limits of AFM's
EDIT
I remember Matt saying from there testing the limit is around 370kw for a single z32
Could try a HPX maf, but i would just replace the ecu if you are looking for over 400kw
Edited by jay-rod
Either you upgrade the AFMs to Nismo and you retune and get a better result, probably to the point where you max out the injectors/turbos and other components become limited.
Or you get rid of the Nistune ECU and buy another ECU and go with a MAP based sensor and forget about AFMs all together and tune the new ECU to the point where injectors/turbos and what not will be limited.
Measures the absolute pressure, which in turn allows you to mitigate the negatives of a AFM.
Eg, reverbaration, dirty afm affecting the signal, removes pretty much any limit on max airflow.
Atmos based blow off valve will not stall an engine
Comming off throttle will be alot "Smoother"
A pressure line will run to a sensor ( think of it like a boost sensor ).
This sensor will either be external, or internal to the ECU.
Most plug in ECU's use internal map sensors, and would be what you want.
You then remove the need for a AFM, and take them completely out of your engine bay.
And run a single boost line to the map sensor
Edited by jay-rod
  • Like 1
Thanks it seems like this is a common question as to which is better? Afm or a plug in ecu which eliminates the afm? The general consensus leads to deleting the afm and spending the money on an ecu? A pair of nismo afm is going to cost 800ish I'm thinking this could be money better spent on an aftermarket ecu
You can't tell that your AFM and Nistune is "maxed out" by reading. Your tuner will tell you when that happens. How many turbos and how many afms do you have? I doubt anything is "maxed out" at 310awkw..if your tuner can't tune it because of the afms get a couple of RB25 afms.
Yes a Link would be great if money is burning a hole in your pocket but the ecu, map sensor, temp sensor, installation and tune won't leave much change out of $3k
won't a haltech platinum pro plug and play eliminate the need for any of those?
Just bought a hpx airflow meter from Nistune. All going well it will be getting tuned on Friday. Nistune say its goo upto 800hp.
What did they cost for the pair if you don't mind me asking?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
