Hello i am currently starting a engine rebuild and wanting opinions from the more experienced than me, which is probably most on this site, i am putting Nitto stroker 2.8 kit into my Gtr r33 2.6 ,also tomei procams duration 270, high , lift 10.8, tomei 1mm oversized valves, my question is would you keep the twin turbos which are garrett 2860-5 which are 6 months old or would you change to a single turbo and if so which one. thank you post-90817-0-19617900-1429898551_thumb.jpg
https://www.sau.com.au/forums/topic/456046-opinions-wanted/
I debated this as well.
Questions you will get:
Pumpgas, racegas, or E85?
Power goal?
Use for the car? Drag, street, road course?
I found that the proven best singles for use on rowdy streetcar builds for nice response have been:
Precision 6262 or 6266
Borg Warner EFR 8374
No doubt these will both out-respond and out-perform your -5's across the board, but on pumpgas the -5's will still make nice powerband while bolting up like factory.
Edited by HarrisRacing
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7522295
You need to provide more information regarding power levels you want to achieve and what you plan to do with the car and other variables which all can factor the decision. You've asked a very broad question and no one can give you a straight up answer or suggestions until you provide us with some more details.
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7522359
There is alot of people talking about response v HP of twins over single, the issue i have with this is people going from a twin setup that hasn't had the support mods done to help the twins work properly to a single that gets all the needed support mods then turn around and tell tails of how much better the single is
So my point, if the twins aren't afforded the same level of supporting mods as the single then saying the single is better is misinformation
Now i'm not saying singles are better or worse, i'm saying compair apples with apples and not oranges
-5s on a 2.8 with the right supporting mods is a good match when setup correctly are a force to be reckoned with
So my opinon is this, get the breathing support mods done and change the 270s back to 260s then dial in for response and enjoy
  • Like 1
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7522645
I agree with this until a point...
I see no reason to go single if the goals are 450-500 whp total. I would suggest -7 to nearly anyone wanting a nice powerful stock feel...it's an inexpensive and reliable bolt-on solution and they just flat work. OR -9 for those who may need a little more HP (500 whp?), but I wouldn't suggest -5 (550-600 whp) to very many and the supporting mods part is actually the big issue for me. I recently had this debate and sold my twins to install a single on my build.
Big power on twins (just turbos - not listing fuel, ecu, etc as this is the same in both cases listed below - prices in US):
Tomei manifolds: $700
Tomei dumps = $550
Turbos (-5) = $2200
downpipe = $300
$3750 Total
Big power on single:
BW 8374 internal Gate turbo = $2300
RAW Brokerage manifold + DP = $2550
$4850 Total
So this setup could cost $1k more, but I would almost guarantee these things:
1) As good, if not better response from the single
2) More Overall HP capability from the single
3) Easier service on the single
4) No "shuffle" from the single
This being said, a divided, TWIN WASTEGATE single is still about as expensive as above, but starts to cramp the engine bay.
I feel like the new BW EFR line carries the most merit in simplicity, cost, technology, included WG, and ease of ownership over ther twins personally.
Again, not saying the twins can't make good HP, but I think Geoff with full-race proved alot with the 8374 EFR on his 2.6 bottom end with his car. (704 whp through a cat with a decent boost threshold on HUGE cams).
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7523392
You can get rid of the tomei manifolds in your twin pricing, they crack and we have managed to see cars with in excess of 600whp with the standard manifolds
You also forgot to factor in the custom intake pipe, intercooler pipe and oil/water feed lines required for the single turbo set up
  • Like 1
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7523413
You could be correct.
but we'd also have to add the intakes to the twins for maxxing them out. Do you know of any proven hardpipe / suction solutions and costs for the twins? Also I would DEF be going braided lines for twins after messing with the hard lines!!
Single piping is dirt cheap after ditching MAFS (which you would in both cases for fairness).
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7523425
Personally I'd the only thing is be doing to the intake is modifying the twin turbo pipe which can be done for under $200aud, I've changed plenty of turbos in GTRs and all of them still have the original hard oil and water feed lines in them cause they do the job perfectly
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7523448
Brett has already said what i was going to but i will add
Going off the dudes pic he already has hard pipes and he mentioned he has near new -5s which flow alot more then -7s
So in this case factor in to the cost the fact he already has pretty much everything needed to make them work, just needs to make sure the manifolds where opened up to flow better into the bigger 0.64 housings instead of the factory 0.48s
Then good dumps front and rest in 3.5" min, shorter duration cams and time them for response and the turbs will take care of the topend
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7523559
Also i have standard manifolds on my 34 that i modded to match the GT-RSs
I also have the factory airbox and intake pipes with Z32 AFM blanks and modded elbows that bolt to turbos and modded twin turbo pipe, with that i made 623hp @ all 4
Granted that is with a RB2630
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7523564
Right, I watched some of your videos...car is nasty! I LIKE IT!
I agree with you especially since he has all the hard parts (didn't notice picture at first!), I wouldn't change a thing...going stroker will only make it better.
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7523993
ok more info , i need to provide , thanks for the replies already, power 500 to 600 horses i would be happy with , pumpgas will be used 98 of course, mods shit were do i start, hpi dump pipes with blitz front to tip exhaust 80mm all the way threw , 1000cc injectors split fire coil pack ,expreme tomei manifold, hks blow off valves sequentials, apexi power fc d jetro, greddy electronic boost control, hks spark amplifier, trust greddy induction kit, genuine nismo intercooler , and im sure theres more just cant think at moment but mostly everything been replaced or upgraded except the engine internals , oh and excedy twin plate clutch , project mu brake kits front and back,tomei oversized oil pump and n1 waterpump brand new engine wire harness. engine will have nitto 2.8 stroker kit , 1mm oversized tomei valves , tomei procam camshafts 270 duration 10.8 lift, tomie adjustable pulleys, twin garrett 2860-5s walbro fuel pump post-90817-0-44250100-1430384593_thumb.jpg
the car im hoping to show it occasional track days but not dragging it ,
Edited by ggs
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7525996
You do not need Tomei manifolds unless you enjoy ripping them off later on to use as a doorstop or a paperweight. I've done a back to back myself, they do not make ANY difference.
Keep the stock BOV's.
Keep the factory airbox
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7526002
Nah Piggy, that's a list of already has :/
So when they crack, and they will, replace with stockers and match port them to suit head and turbos
500 at the wheels will be easy with what you have, 600 will be easier with a 3.5" exhaust
Get rid of the HKS spark amplifier, it will cook your coils at some point, splitfires are ok for 600 but the Mojo LS2 coil kit with built in ignitors would be better, they have a kit that plugs in and deletes the ignitor
https://www.sau.com.au/forums/topic/456046-opinions-wanted/#findComment-7526007
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
