  • 4 weeks later...
Just a few updates.
Went to get it tuned to get it to run better and found out it had a leak from the gasket on the intake manifold.
And because this used to run gas i had blocked up the holes on the runners that the gas was injected into. So while i had the inlet mani off etc i thought id replace it with one without holes.
What a shitty job it is to do! But all done and will go in for a tune again this week sometime
Also replaced my front seats with GTR ones.
Looking for some rear seats in good nic if anyone has any
bought a 32 GTR spoiler and boot to put on....
Got the car tuned, dyno sheet below.
Still having a problem with the car ummm, cutting out and hesitating then like bunny hopping and wont rev. Tuner thinks either the AFM or the crank angle sensor.
Will find an AFM asap and try that. easiest thing to try
  • 1 month later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
