I have searched for previous threads, but have not found an answer to this quesiton. I know tha everyone has different views about copper/platinum/iridium. Personally, i believe in using coppers, and changing them frequenty.
My question is to do with the gapping. Stock gapping is 1.1mm. yet, when running stock boost, i tend to get misfire. Plugs have not been changed ever since i've got the car (probably 15000 ks). Should I get plugs gapped at 1.1mm? (car is running stock boost, just zorst and air filter). i've noticed that some of you guys run 0.8 or 0.7. is this only if you run more boost? like would it be beneficial to run 0.8 mm even at stock boost?
Is regapping plugs bad? i've got a feeler gauge and i was wondering if it is ok to just regap them and put them back in after a clean? or should I just buy new ones?
https://www.sau.com.au/forums/topic/45612-spark-plugs/
what is the heat rating of a spark plug?
I pulled my cover plugs out, haven't been changed for 20000 ks. They are all dirty and gapped at 1.4 mm.
I was thinking about just buying some new ngk plugs. How do i decide which heat rating to get, and what would be the difference between a 1.1m and a 0.8 m gap? stock boost, just zorst and airfilter
https://www.sau.com.au/forums/topic/45612-spark-plugs/#findComment-928715
my 33 would mis-fire when it had only an exhaust and pod and no boost. used 6 heat range coppers gapped to 0.8 and it solved all my problems. i think the 0.8 gapped ngk copper is bcpr6es (dont get bcpr6es-11 - 1.1gap).
-rb25
U can get the bcpr6es-11 which are already gapped to 1.1mm and simply tap them in a bit to whatever u desire with the use of feeler gauges.
https://www.sau.com.au/forums/topic/45612-spark-plugs/#findComment-928791
are they gapped to 1.4 or worn to 1.4? i would be fixing that asap, u will notice a big difference. Nissan recommends heat range 5 but most people say to use 1 range higher for a certain hp increase from stock.
https://www.sau.com.au/forums/topic/45612-spark-plugs/#findComment-928796
Hey ive had my 32 for about a month or so i dont think the spark plugs have been changed, im all new to this, after just reading all the posts it still doesnt make sense. Im runnig 10 psi on it exhaust, SAFC 2 cold air intake and dump pipe from turbo, and i think i should change the spark plugs for peace of mind does anyone know what sought i should get copper/irridium/?
What gapping should i have and stuff like that. It's for an R32 GTS-T.
Car approx has 86,500kms on the clock.
https://www.sau.com.au/forums/topic/45612-spark-plugs/#findComment-931879
shark33: my theories are as follows:
a car with standard ecu runs rich and fouls plugs quickly. in this case, use copper plugs and change regularly. now a car with a tuned ecu or safc or the like will run leaner afr's so plugs dont foul as fast and you dont have to change them as often.
So If i was using a standard ecu id use coppers, any aftermarket ecu or piggyback, id be looking at platinums or iridiums. I have recently gone from coppers 6 heat to platinums 7 heat after putting a powerfc in.
-rb25
https://www.sau.com.au/forums/topic/45612-spark-plugs/#findComment-932180
I just changed my spark plugs..
I went from PFR5A-11..
and put a set of BCPR6ES in my stock r32 gtst (115 on the clock)
I cant rememebr what the gapping is of these, but it did not have the '11" on the box, which means that its either 1.1 or 0.9 i think the guy at repco explained.
Dont seem to be missing as far as im aware?
https://www.sau.com.au/forums/topic/45612-spark-plugs/#findComment-932497
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
