Fellow sau members
My car has a million problems need help solving one my old r33 did the same I just sold the thing without fixing it this one does it all the time
Problem
When the cars hot after a while I don't mean running temp more like drive for half an hour. My car seems to all of a sudden loose power after a quarter throttle
Things I noticed are the exhaust note hangs sounds like the car is struggling (which it is) it sounds like it's slowly revving out but takes forever
Natural instinct makes me back off but if I keep the throttle down it really goes nowhere!
Since I have been swamped with other things it's been put off for a while until I get the cars other issues fixed
It's really annoying and I can't overtake anyone with the power of a charade
While I'm writing a thread does anyone know why it idles high? 1100 rpm.
Thanks in advance
https://www.sau.com.au/forums/topic/456157-problem-when-cars-warm-rb20det/
Yeah I'll just replace is. Is this in reference to my idle issue or nugget when hot issue
(Please note that my thermostat is new and the car gets up to "running temperature" quickly it's drives longer then say 30 minutes sometimes longer before it does it.
(It is accumulative so if I do a lot of short trips it still does it)
Both - Idle and Nugget
Edit: Basically the ECTS (Water coolant Sensor) is sending poor info to the ECU which is getting info from other sensors as well.
By the way it should cost around $40-50 and you can change it yourself
Edited by Sinista32
20+ years old car now man, things start to get old/worn/brittle. Start slowly gathering parts and replace them (e.g. coilpacks + harness + from performance-wise, throw new BCPR6ES-11 spark plugs in as well).
Having a standard engine is a bonus, less shit to worry about when diagnosing.
I miss my black GTS-t :(
The larger the gap the better/bigger the spark therefore better the burn :)
With a stock car running average boost your best off with 1.1mm on your spark plugs.
When you modify and wind up the wick wait until you get issues prior to reducing the gap down.
There wont be any issues running a smaller gap with new splitfires BUT it's not optimum. See first line ^^
Edited by Sinista32
Cheers sinista sounds like a plan I'll give them a shot
And cheers got that jiffo
I'm not the smartest with a multimeter so how exactly do I set it up to measure the ohms and I'm obviously unplugging the sensor correct?
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
