Because you get to a point where you split the block in 1/2 horizontally.
Was at Sydney dragway when Maatouks VL did it. Quite a sight.
Is it for everyone, no. But right at the top end of the scale, there must be a need.
Completely agree with you - there's an rb30 bottom end on ebay for $100
So want, 25kgs light isn't a big deal when talking a 1700kg car but being able to set deck height for 2630 and not having to use adaptor for 4WD means heaps :)
isn't Bullet the dudes that put 1UZs in MX-5, i thought they where in QLD
Clearly these are for cars that weigh in the 1100kg range, not for street cars. It's gorgeous and it will work but I've genuinely no idea why they machined it with water galleries.
Bullet Cylinder Heads aren't the same company as the Bullet you're thinking of.
Also thats a standard RB26 alloy head casting being CNC ported, not a billet head. It's how they did mine.
also just fyi
they posted this up yesterday
11174770_963462717032437_270913565015250
It's a theoretical shame the max bore wasn't 90mm
Std. Clearance being 94mm crank, squeezing a custom 95mm would give you 3626cc, over a litre more capacity in a gtr.
Probably not a concern in its intended application
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
