Slides up and a little towards the hole. They can be a little tight though...
Easier when the fuel level is low and you can get a torch in there to see how it works.
I only have a lighter, that should work;
Right?
  • Like 2
Right?
i know this is bad. But i had to do this to check the pump and fittings while it was out of the tank. Old girl let out in a dark alley and my phone went dead.
Everything went better than expected, was home by 2am haha
grate the car god's can to help me, GOT IT OUT after 2 day's I did bend out the clip on the day 1 but no luck on day 2 I got the biggest pair of pliers on to the side of the cradle & pulled it up & out what bitch of a job. Thank you all for all of the reply's .
Wait til you try getting it back in; that's the fun part
Also, how good is that feeling when you finally arrive home circa midnight after a long night of working on a car? Drive home is the sweetest, especially if you're enjoying the fix/modification you just made.
Or better yet, the sock is around the wrong way. So your fun drive home turns into a stop start drive home.
  • Like 1
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
