1 hour ago, Robzilla32 said:
The factory mesh looks so crisp and clean on your car. Is it new or did you clean it up? If the latter, what did you clean it with?
Cheers
Rob
i bought the mesh second hand actually, the coating on it was peeling a bit so i peeled off whatever wasnt secure. primed it up and painted it with satin finish black paint from a spray can. i put stacks of coats on so its nice and thick. probably looks so 'crisp' because i polished up the end tanks on the cooler before i refitted the bumper.
dont know how everyone else does it but my bar is a mission to take off. i still have the factory brake ducts, guard liners fitted, bolts for the lip as well as everywhere else. basically to fit the mesh its a bumper off job. not something i really want to do too often.
  • Like 2
  • 4 months later...
  • 1 month later...
8 hours ago, okooko said:
hope the rebuild is going well, any updates?
Hiya! Progress has been slow. I have sorted out the clutch thankfully. I bought a nismo twin plate c spec in the pull type. I didnt check my current setup which was a push type.
I contacted rhdjapan and they wanted a 35% restocking fee plus freight. If you know what these clutches are worth, you can do the math. I had a small heart attack lol.
I called a couple of local retailers to see if they wanted to swap for the correct type but i knew it was a long shot. Its like buying from woolworths and returning it to coles. Luckily the yodas on here gave me the right advice. Turns out i do have a pull type box which was converted to push.
I ended up getting what i needed from Skyline Spares at a bargain. Spent one night draining the box fluid, changing front cover and installed fork and slave.
Also recieved nismo engine mounts, because why not.
2017-04-09_05-59-212017-04-09_05-59-54
I dropped the clutch kit off at the workshop because they need to balance the flywheel to the crank but I haven't been passed in a couple weeks. I dare say the motor is back from machining by now.
Basically, engine is staying 2.6 with a decent bottom end and headservice with cams.
Apart from that i am in cleaning mode! I stripped the paint off the inlet manifold and i was unsure weather to polish this. I am reluctant to paint it because it marks so easily. Ill post up pics but after stripping it and cleaning up with a wire brush by hand it didnt turn put too bad. I figure ill keep it a 'natural' finish.
Im thinking glass black for the engine covers. Thoughts?
  • Like 1
I personally like the stock black non-gloss texture, even if I did a rebuild, I'd at most redo it in the same color.
Revisited this thread as i remembered you made some comments around putting the C Pillars which i started tonight after taking out all my seats and giving the carpet a good clean. no coins or anything just crumbs possible KFC or maccas...
this thread made me wana do stuff haha - cheers for that
  • Like 1
I dont mind the finish on the stock covers either but with the motor apart i figure ill give them a refresh. While thw bay is empty i have given it a good scrub and got rid of 20 years worth of crud. Looks so much better. There are a few marks and scratches from general wear and tear but i wont be repainting the bay. Apart from the added cost i fear the bay will end up too neat and i will be way to pedantic everytime i work on it.
In addition to cleaning parts i cleaned and retaped the engine loom. Its hardly noticeable but its easy to do and the finish product looks a lot better than old cracked or oily loom.
As for the engine covers, gloss black is like an oem+ option i think. Candy red is over done imo.
Have you finished installed the c pillars and bask in the sexiness of them? I think they really highlight the tidyness because you can see them delaminating from the outside which makes a good car look rough
  • Like 1
I'd likely paint the engine bay while I'm at it just like refreshing the covers but I'm not sure the costs or the existing condition of your engine bay.
Don't think candy red is a color you'd redo your stock covers in. rather something you get from a 34 motor. the 'RB26' lettering is slightly different on the 34 motors - slightly thinner.
I only got around to pulling the left one off, breaking every single clip from the existing one... I'll chuck on the new ones this weekend hopefully.
Wouldn't mind giving the seats steam clean but probably won't get time to before they go back in
  • Like 1
Yes i beleive the 34 timing cover is plastic and yes it does have a different font.
Out with the old!!! So satisfying sticking the old ones in the bin! I have had the seats steam cleaned before. Takes about 10 mins to take the front and rear seats out. Because there are no electrics on the seats you can get right in there with the cleaning.
  • Like 1
havent had much daylight recently only getting 30mins to do stuff after work and before its dark
drivers weatherstrip is off, the old one had a torn corner. my retainers are decent enough not to warrant a new set.
surprised how the window inner/outer mouldings, weatherstrips and retainers are about 2k all up... only replace when broken haha and very selectively too...
yeah its a quick job pulling the seats out/in again.
  • Like 1
  • 1 month later...
I think everything ive done in the car has been at night. Its a major pain in the ass.
Small progress. Block is back from machining. Looks great. Will make for a pretty coffee table :P
IMG_20170608_162502_448
At the moment im just wiring up a few sensors for the haltech. Has anyone moved the fuel filter to the rear of the car?
  • Like 2
So im using ahaltech pro plug in plus io box. Wired up the io box last night. Blue led light stays on when power is on, no red led on io box.
Haltechs leds do not light up at all. Is this normal?
Theres no engine in the car and when i turn the key i dont even have reds. Yet to plug the laptop in.
Im thinking because there are a stack of earths not connected in the engine bay there are a range of open circuits. Am i wrong?
Edited by WantGTR
  • 1 month later...
Those engine covers are temporary. These babies are keep safe and wrapped up till the end...
20170628_195842
Mines cam baffles and 12an breathers fitted.
Need to order a new coilpack ornament cover. Might as well get new bolts. These covers have cost a small fortune on their own.
  • Like 2
20170805_223011
Stock paper gaskets are being replaced with nitto items. These are fantastic quality.
I opted for a justjap heater hose kit. I know threads on here recommend oem hoses but these look way tougher than stock. Justjap have been selling these kits for years, i figure they cant be that bad. Lol
  • Like 2
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
