Wondering if anyone's done this before?
Before I continue, I know the Oil gauge sucks, I know the Boost doesn't read >10 and isn't measured in PSI; don't care, aiming for a stock look that looks nice.
The nitty gritty...
I know volts/temp work fine.
Wondering how to convert current mechanical boost line / VAC line to electronic? Under the impression that R32 non GTR don't have a stock electronic boost solenoid? How would I go about working around this?
https://www.sau.com.au/forums/topic/456401-r32-gtr-center-gauges-into-gts4/
The nitty gritty...
If you Google "R32 centre gauges into GTST" you will find that indeed it has been done (many times) before and all will be revealed.
personally I wouldn't bother. Only because the gauges are so old now that they are mostly useless.
My voltage gauge reads 11.5 when it's really at 14v
my boost gauge reads -200mmhg when it's at atmospheric pressure (engine off)
oil temp peaked at 100c on the track where it's unlikely to have been less than 120. I don't have another way of measuring unfortunately.
I don't mean to rain on your parade. The stock look is nice but the gauges belong in the bin unfortunately. If you like a clean look, the Defi Din triple gauge option would be nice; although it's $500 or so
If you followed your own advice, you'd fine that's not true.
There is no information re: whether or not the GTR gauges are plug & play into GTST/4. Most aftermarket gauges are mechanical and GTR are electronic; hence thread.
Anfanee, are the Defi temp/temp/press only? Or is there an option w/ a Boost gauge?
+1 to the defi din gauges. Got them setting next to me.
I can haz for free anfanee?
nah no boost gauge unfortunately
Can't imagine wanting boost in your center console, needs to be somewhere you can see it when you're hektic boostin' and should hopefully have your eyes on the road... :yes:
Meh. I only ever used the boost gauge for double checking rpm and max boost because of mbc's problems with the ball and spring. Boost gauge is now in the glovebox where it serves it's purpose for double checking.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
