Hi guys
i'm selling most of my spare car parts I have accumulated over the years due to new commitment.
BNR32
Front Strut Bar, manufacture unknown there is some scratches - $65
Front Strut Bar, manufacture Aiba, - $65
Front Strut Bar, Cusco, - $85
Rear Strut Bar , Cusco - $85
Floor Cross Bar, Do-Luck - $250
Genuine weather shield NEW two pairs - $350 each pair
Blitz twin core radiator in good condition, no leaks, comes with fan shroud and radiator cap $ 390
Tein Comfort Sport, 16 Stage damping, 5k and 4K spring Rate no leaks or Knocks in good condition - $1400
Ohlins Full Tap 20 stage adjustable coilover with hyper coiler springs, 9k and 7k spring rate, no knocks or leaks, very good condition - $2650
Trust Oil cooler kit in very good condition $350
HKS Oil Cooler Kit $400
Ikeya Formula adjustable camber Arm Rear, Near new condition $410
Nismo 600cc Injectors good condition $520
Greedy 4pcs intercooler pipe kit $370
ATS twin carbon plate clutch push type comes with flywheel, both clutch plates are at thickness of 3.9mm plenty of life left in them - $820
Nismo Front and Rear Sway bar set front sway bar 22.2mm rear is 27.2mm - $500
Cusco 7 point roll cage in good condition with everything you need for fitment, around the dash. - $700
Okuyama 6 point though dash Roll cage in good condition everything everything you need for fitment - $520
Stainless steel front pipe two 70mm to 80mm brand unknown, no leaks - $200
Nismo GT Pro LSD 1.5 way final gear ratio 37:9 in very good condition - $1000
R32 GTST GTS
Genuine Weather Shield New - $240
BCNR33
Genuine weather shield NEW - $350
Ohlins DFV coilovers, travelled 3000kms 9k and 8k spring rate 20stage adjustable near new condition $2700
HKS Hypermax 4 GT 30stage damping 8k and 7k spring rate in good condition, no leaks or knocks $1600
O2 sensor x2 $120
ECR33
Nismo G-attack s tune 4 stage damping, no leaks good condition $950
Tein Type RS circuit master coilover 16stage damping and rebound adjustment, good condition 10k and 9k spring rate $1750.
Ganador Exhuast 80mm to 90mm tail is 120mm. no leaks, good condition $ 550
BNR34
Nismo R tune Air duct, Brand new - $490
Tein Street Flex Coilovers 16stage damper adjustable 8k and 7k spring rate no leaks or knocks good condition - $1050
Kakimoto Cat back Regu06 80mm to 90mm and 110mm minor scratch marks but no leaks - $620
ER34
Twin core Radiator, 50mm core size no leaks and good condition - $ 190
Trust Oil Cooler kit good condition - $500
Other
Nismo Clear side indicator Brand New - $90
Nismo Carbon fiber inside Mirror cover Brand new R32 and R33 - $260
Can ship anywhere at buyers expense.
I will be uploading the photos shortly
Please do no hesitate to PM me
thank you
Hi Roy,
For my BNR32, I'd like to buy the...
* Nismo F&R sway bar set if HD links/bushes are top condition. Pics?
* Nismo c/f interior rear vision mirror cover
...please.
I can pick up from Mortdale. Ta
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
