the car is running perfectly (aside from the leak), but it's unregistered so I can't get it down to bunbury. I can nearly reach the hose with my fingers from the top of the engine, they're just not long enough.
That being said, I don't have the know-how to remove all of that stuff, and it sounds near impossible to do in my drive way.... hmm. Will most likely look into it tomorrow when the sun is up and come up with a plan.
If anyone is in the Forrestfield Area with the know-how and feel like helping, hit me up so can plan this better.
Was thinking of starting a thread like the music one "what are you listining to" but call it "what are you laughing at" not having facepage i miss out on some of these.
Tried the lulz thread?
  • Like 1
I'll upload two more photos in an attempt to show where it is, in one of the photos of can clearly see it gushing out coolant. It's at the rear of the motor, just behind the rocker cover underneath another pipe.
http://imgur.com/a/bTzuJ
Yeah, not many 4 door R33 GTST's out there with a manual transmission. Don't worry, I'll fix that problem eventually, right now I need to get this car registered.
Besides - Auto's win races ;)
Edited by Manne
  • Like 2
Manne, you'll be right. I had to do that same hose on a 300zx tuesday, You have 0 things to complain about
I'm not complaining, I value the educational experience.
any advice? approach from under the engine or above? I was reading somewhere that removing the starter motor gives you more access?
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
