I know right?
I've noticed R33 parts are pretty common though. The wheel Arch thingy that I need, not so common. It seems to be the one part that EVERY ONE needs.
Give him a call and his name is Louis[emoji13] make sure you have 1lt or Choca mocha handy for done deal X
Not really any use for me. Wouldn't hurt to have, I guess. The stuff I really wanted is gone. a CAT wouldn't be a bad idea...but I can't fit it in my car I don't think. Don't worry about it Ellie. Thank you for looking out for me though!, I appreciate that!.
as for FabCar... I've heard some shady things, their reviews aren't too flashy either, never dealt with them personally though.
  • Like 1
No worries at all [emoji13] I'll keep looking out if there's any [emoji3]
Saw their name on the side of a racecar recently
What you getting done?
Yer i checked out that white clean GT-R but out in the yard i seen another r34 gtr but the front looked like it was in a crash n they fixing it just put me a step backwards
Oh there is a topic about that car, called pre inspection something something in wa section
Thanks
I actually had a read of that post about a week ago i just can't believe I did not connect the dots i feel very stupid now [emoji52]
Thanks
Its a long shot but try calling some of the tuners I use C-Red, mark is a top bloke see if he or any other tuners are aware if any customers are selling and having worked on the cars can vouch for em? Like I said its just an idea and if they are aware you want one might be able to keep an eye and ear out.
  • Like 1
Hi everyone
Anyone have any experience with fabcar ?
Their cars used to be overpriced, but they had some good stock and have been around for years.
I remember they had a fkn mint Aristo in there once but they wanted $19k for it (this could have been 5 years ago), it was tempting but still overpriced for the time.
They have a Nice White r34 GT-R for sale
Make sure you use these guys before purchasing a decent car like that
https://www.facebook.com/Japanese.Odometercheck/?fref=ts
  • Like 1
anyone know if Wheel Arch Liners are required to get a car over the pits? (every wrecker i've called, and every gumtree add I've responded to, don't have them).
try calling KYP at Welshpool. They may have some, cant be sure.
  • Like 1
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
