I know right?
I've noticed R33 parts are pretty common though. The wheel Arch thingy that I need, not so common. It seems to be the one part that EVERY ONE needs.
Give him a call and his name is Louis[emoji13] make sure you have 1lt or Choca mocha handy for done deal X
Not really any use for me. Wouldn't hurt to have, I guess. The stuff I really wanted is gone. a CAT wouldn't be a bad idea...but I can't fit it in my car I don't think. Don't worry about it Ellie. Thank you for looking out for me though!, I appreciate that!.
as for FabCar... I've heard some shady things, their reviews aren't too flashy either, never dealt with them personally though.
  • Like 1
No worries at all [emoji13] I'll keep looking out if there's any [emoji3]
Saw their name on the side of a racecar recently
What you getting done?
Yer i checked out that white clean GT-R but out in the yard i seen another r34 gtr but the front looked like it was in a crash n they fixing it just put me a step backwards
Oh there is a topic about that car, called pre inspection something something in wa section
Thanks
I actually had a read of that post about a week ago i just can't believe I did not connect the dots i feel very stupid now [emoji52]
Thanks
Its a long shot but try calling some of the tuners I use C-Red, mark is a top bloke see if he or any other tuners are aware if any customers are selling and having worked on the cars can vouch for em? Like I said its just an idea and if they are aware you want one might be able to keep an eye and ear out.
  • Like 1
Hi everyone
Anyone have any experience with fabcar ?
Their cars used to be overpriced, but they had some good stock and have been around for years.
I remember they had a fkn mint Aristo in there once but they wanted $19k for it (this could have been 5 years ago), it was tempting but still overpriced for the time.
They have a Nice White r34 GT-R for sale
Make sure you use these guys before purchasing a decent car like that
https://www.facebook.com/Japanese.Odometercheck/?fref=ts
  • Like 1
anyone know if Wheel Arch Liners are required to get a car over the pits? (every wrecker i've called, and every gumtree add I've responded to, don't have them).
try calling KYP at Welshpool. They may have some, cant be sure.
  • Like 1
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
