I definitely think thats a good idea of asking the turners[emoji12] , it this point of time i think i need to take a chill pill i still can't believe i break through the wife of years of brainwashing [emoji38] until yesterday she said I've seen this cheapish white GT-R at a dealer its Wednesday car night im gobsmacked n over excited
Edited by pol1on1
  • Like 2
try calling KYP at Welshpool. They may have some, cant be sure.
I called them two days ago and they said they'd call me back and never did. They're only around the corner from me so I'm just gonna drive up today and see what they have. Japwreck in cannington don't have any r33's right now either.
who did you talk to...?
Afternoon all.
Manne, As far as i am aware the inner guards are required. There are wiring harnesses either side that sit above them so it's a good idea to have them there as protection
Thanks buddy. I rung KYP again half an hour ago, the same guy said "Must be the new guy!, we fired him!" and then took my number and told me he would call me back... Why do I get the feeling I am being taken for a run. Don't they want my money?
Yeah they are ok, havent purchased anything from them since they dropped my laurel half cut off the fork lift 10 years ago. Best to go and see them. If they anything like here, the phone rings every 5 mins and they can't chase anything up
Going there would be best. If they aren't too busy, look for Ben and tell him I sent you. And yea, he's family
They have been improving, and have come a long way. Still much to do IMO, but yea, still hit and miss
Lol,they did eh? I'm gonna bring it up when I go over on the weekend
Ok, so I got the wheel guard from them, I did name drop you Colin don't know if it helped or not. They said for ~$800 they could get my skyline inspection ready, but that includes fixing the tacho and removing the tint.
I wonder how much it'd be if I did that myself (which I can do) and just let them do engine stuff.
oh, and they gave me two guards for her, an R33 (for the top) and an R34 for the front, which they INSISTED does fit the R33, all up both pieces cost $80.
Edited by Manne
"Fit" is a loosely used word here hahaha, it might fit, shrugs....bring it back and ask for your money if it doesn't.
$800? What else do you need done anyway other than the tacho and tint?
A box for my old filter (they were gonna throw the stock on) and mesh the front grill (I have the mesh already)
and my electric mirrors need fixing. The left one is fine, the right one only folds in. And when I tell the right one to fold out...the left one folds out...
Edited by Manne
Ugh electrical stuff PITA!
Filter wise, I'd use the stock ones as well. Inspectors can be assholes when they see after market stuff. Or build an enclosure. Filters always need to be enclosed. So I guess stock would be easiest.
Edited by colin.ssc
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
