I definitely think thats a good idea of asking the turners[emoji12] , it this point of time i think i need to take a chill pill i still can't believe i break through the wife of years of brainwashing [emoji38] until yesterday she said I've seen this cheapish white GT-R at a dealer its Wednesday car night im gobsmacked n over excited
Edited by pol1on1
  • Like 2
try calling KYP at Welshpool. They may have some, cant be sure.
I called them two days ago and they said they'd call me back and never did. They're only around the corner from me so I'm just gonna drive up today and see what they have. Japwreck in cannington don't have any r33's right now either.
who did you talk to...?
Afternoon all.
Manne, As far as i am aware the inner guards are required. There are wiring harnesses either side that sit above them so it's a good idea to have them there as protection
Thanks buddy. I rung KYP again half an hour ago, the same guy said "Must be the new guy!, we fired him!" and then took my number and told me he would call me back... Why do I get the feeling I am being taken for a run. Don't they want my money?
Yeah they are ok, havent purchased anything from them since they dropped my laurel half cut off the fork lift 10 years ago. Best to go and see them. If they anything like here, the phone rings every 5 mins and they can't chase anything up
Going there would be best. If they aren't too busy, look for Ben and tell him I sent you. And yea, he's family
They have been improving, and have come a long way. Still much to do IMO, but yea, still hit and miss
Lol,they did eh? I'm gonna bring it up when I go over on the weekend
Ok, so I got the wheel guard from them, I did name drop you Colin don't know if it helped or not. They said for ~$800 they could get my skyline inspection ready, but that includes fixing the tacho and removing the tint.
I wonder how much it'd be if I did that myself (which I can do) and just let them do engine stuff.
oh, and they gave me two guards for her, an R33 (for the top) and an R34 for the front, which they INSISTED does fit the R33, all up both pieces cost $80.
Edited by Manne
"Fit" is a loosely used word here hahaha, it might fit, shrugs....bring it back and ask for your money if it doesn't.
$800? What else do you need done anyway other than the tacho and tint?
A box for my old filter (they were gonna throw the stock on) and mesh the front grill (I have the mesh already)
and my electric mirrors need fixing. The left one is fine, the right one only folds in. And when I tell the right one to fold out...the left one folds out...
Edited by Manne
Ugh electrical stuff PITA!
Filter wise, I'd use the stock ones as well. Inspectors can be assholes when they see after market stuff. Or build an enclosure. Filters always need to be enclosed. So I guess stock would be easiest.
Edited by colin.ssc
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
