WE haven't discussed this,
I haven't said yes...
:P
We advertise with some Radio company called "Red FM" (don't worry, I hadn't heard of them either) and they are entering a car and want a few of us to drive and stuff.
:P
Hate that station. Should be Repeat FM
They broadcast on heaps of FIFO sites and give everyone the shits.
Tell them I work for your business? ;)
Just cough up the money to drive ;)
Also going to pass this feedback onto the guy who deals with our Red FM account ;)
Double their quotes?
In fairness I do think the same of almost all commercial radio. Only a couple I'll listen to from time to time
As do I, and we are both exactly the target market that we're going for, so that says something.
Do they actually have DJs or do they just have an iPod on repeat all day?
As far as radio goes I only listen to Triple J and occassionally RTR FM (Perth's community FM station)
All recorded with snippets of interviews etc from shared presenters.
The thing they don't seem to get is many people work with the radio next to them for 8-12 hours.
If I only heard radio in the car going to work I wouldn't mind the top 20 songs getting played often
But in a 12 hour shift I hear all of the top 20 played 4-6 times everyday
I only listen to coast fm in mandurah or mix 94.5 If I'm in Perth
Bunburys hot fm is my least favourite as they target 15-25 yr group and they all talk like children and so do most of the callers
Don't fuel my imagination, I half suspected that. My money is on the previous owner. Lots of weird stuff being discovered the more I work on it.
Hahahaha I don't think they are that dodgy just yet.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
