Why are limes so damn expesnive at the moment?
$10 p/kilo at the spudshed, or $1.20 each at coles (at about 100 grams each thats $12 p/kilo!)
What gives Perth?
I diy for my work / daily car but won't take risk for my 35 [emoji22] too complicated ! How did you go with fixing your door? Should we organise some fund raising car wash towards your door ?
I've been quoted $1000 to get it fixed which is going to take me about a month to get, mortgage and bills and what not. I'm not going to ask for donations or a fund-raiser for something like this, it's purely on me and my responsibility. That being said If anyone needs some odd jobs done or is willing to pay me to wash their cars I'd be delighted to... Or if some one would buy my subs/amp ahaha. Other than that the cars just benched until I can afford to fix it/change the tires.
Thanks for the thoughts though.
  • Like 1
What gives Perth?
buy a tree and keep in a pot. the dwarf ones at bunnings are around $20-30 and dont grow very big.
graft a lemon branch onto a lime and have both fruit from the same tree
speaking of fruit ive now got orange, lemonade, pink lady, granny smith, mulberry and 2 Nashi trees in the ground
want apricot, cherry and a dwarf avocado tree next
Canningvale markets on Sunday mornings have better/healthier and cheaper fruit trees than Bunnings IMO
Or even Marangaroo on Saturday mornings.
i went up to guildford garden centre who seems to specialise in dwarf fruit trees for some of them
  • Like 2
That's fine too =) Bunnings charges wayyyy too much for what you get. Just sayin
actually i shopped around a bit and i didnt think they were too bad,
i bought citrus from there and it was in good shape and $20 each for dwarfs
i only went to guildford cos they were the only ones who seem to do Nashi pears and their website shows stock levels which is handy
Hmmm.... maybe
Hmm interesting. I have been looking at the plants there for ages and always found them to be quite pricey. Maybe I haven't been looking at fruit ones for awhile. Or the Bunnings near me is just shit with their quality of plants. Good to know about Guildford though, might take a look if they have anything I want hehe
https://www.bunnings.com.au/200mm-sublime-lime-tree_p3661591
$28 for a lime tree, if I kept it alive it would pay off.
How hard is it to graft a lemon branch on?
yeah fruit wise they are well priced and both bunnings in bunno they are in good shape. local nurseries dont do dwarfs
not sure how they compare with trees
ive never tried but heard its easy
not sure when best time to do it is either
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
