6 minutes ago, turboedsloth said:
I got told off by your mate last night Lachy. Apparently 26's are a waste of money aswell as T04z's . I might just put a 302 in it :wacko:
Lol, who's my mate?
3 hours ago, Hank Scorpio said:
Lol, who's my mate?
Drives a yellow volvo
2 hours ago, Hank Scorpio said:
TO4s are pretty old tech though
Been looking at GTX35's and 3788's as an option
  • Like 1
Oh, hahahaha!!!
GTX35 will be quite responsive and powerful, especially on E85
