9 days before my half Marathon [emoji24] 5 days on clean eating challenge and I'm physically dead ! I want my Nandos [emoji24][emoji24]
And not sure what's happening with Galvesport [emoji35] paid for my endless break pads and rotors a week and half and still haven't heard from them [emoji57] tracking numbers for parts of at least let me know what's happening would be nice !
  • Like 2
Morning Trevo ! Take It easy and speedy recovery [emoji1320]
No way. Busy moving. Hectic day
Ended up with eye, throat and chest infection. Doc told me I'm too run down and need a rest and antibiotics.
That sux mate, so got the car back from Mark, number is a little lower than I thought it would be 215 but Mark said his dyno reads lower than others?? Still runs very nice now
What were you expecting?
Sorry I forgot mods you have?
Was hoping to be closer to 250 but I guess I need more mods, it has only got 3" exhaust, pod, boost controller and nistune and an auto slush box. Mark said my fuel was shit and my fuel pump maxed out. FMIC next week and better fuel only BP obviously shell sell crap
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
