50 minutes ago, shoey85 said:
Any one experience a water pump bearing or idler pully failure? I think I have had one die on me, belt screech and a typical knocking from a bearing FFS, back to Mark tomorrow!
Yep had a pootrol come in last week with "squealy belt". Water pump bearing had let go and was screaming its box off
  • Like 1
So went to Mark and he basically knew what it was after 10 seconds, my alternator came lose and the bolt was hitting the fan, he fixed it up on the spot[emoji4] then sent me to get him a carton [emoji482] all good drove it home [emoji6]
  • Like 2
2 hours ago, shoey85 said:
So went to Mark and he basically knew what it was after 10 seconds, my alternator came lose and the bolt was hitting the fan, he fixed it up on the spotemoji4.png then sent me to get him a carton emoji482.png all good drove it home emoji6.png
This is one of the reasons I love C-Red.
  • Like 1
Found this post in trending
Wonder if anyone can help.
Btw in sau app do you find it hard to find this thread ? ?
Subscribe to topic.
I just use "participated" most of the time and it's always not too far down
  • Like 2
Yeah nah i think im having more then general issues.
Eg.. my http link did not post ive had no participate activities in the lasth months or so and that what i use to use and now just finding this thread was a challenge but i re subscribe to it.
Time will tell until the next update.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
