2 minutes ago, pol1on1 said:
Yeah nah i think im having more then general issues.
Eg.. my http link did not post ive had no participate activities in the lasth months or so and that what i use to use and now just finding this thread was a challenge but i re subscribe to it.
Time will tell until the next update.
works well for me
Found a good article about how to "tune" my boost controller rather than just set.
Checked mine and the gain rate was set at only 7% and limiter not setup.
Preliminary test appeared to gain response from 1bar @3400 down to 1bar@3250 at 70% gain and not spiking.
Fuel light was on so will further adjust and set limiter later
  • Like 3
My mate has nearly finished his rx7 (series 3) build, yesterday sent it off for a tune and told them to do a conservitive tune it came back at just over 415 i think, i told him im not going in it with him driving. Anyway last night he took it for a spin and he sent me a pic will post it up in my next post
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
