Morning All,
Finally all parts arrived , got my car booked in with GS this morning.
One thing for sure this will be my last service / visit with them.
If you guys know anyone that have a good attitude/ friendly mechanics and knows well about my Car , please share the details.
GV is f#%^*+ joke
To deal with !
You should ask Mark at C-Red 08 9356 3000
He has always helped me out
  • Like 2
8 hours ago, ElleAli76 said:
Morning All,
GV is f#%^*+ joke
To deal with !
Marc from C-Red. I know it's far for you...but he's worth it. I would just call him, talk to him about what you want and see how you feel.
Holy crap, I posted this without seeing Z00key and Shoey's posts ahaha.
As for a bike ride- Sure, but my bikes nowhere near is fast as yours.
Edited by Manne
Didn't read every post before I replied.
  • Like 2
Just need a packed lunch and water bag to get there and a spare tank of juice for the return [emoji6]
Mate, australind is part of south mandurah,
And mandurah is a suburb of perth,
So it's just down the road.
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
