Morning All I have question, my lawn mower guy came yesterday and accidentally brake the window , mowing close to the pebbles area , what do I do and who should pay for the cost to fix it38b78a0ced223a93e82c2e1451354455.jpg
Ellie, I would ring your lawn Mower guy, and tell him. The company he works for/his business should be insured in case this happens, and s/he should pay to fix it.
Edited by Manne
  • Like 1
his insurance
  • Like 1
Afternoon all
Suspension/steering parts headed your way from Lachy. Let me know how much I owe you for freight.
I'm on days off now if you wanna call past for a beer and check out the pad after work
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
