d3aedc9ff9f7fba2d5bb318e4f078c0e.jpg&key=6466e9d43e486d7c9e0463aef11bf4c66810e9c73bf0f333c2b5cca7db60e91c
For who dont have FB [emoji12]
And sold 12hrs later awaiting payment.
I wish i was the lucky buyer i would sleep in it for a week. !!!!!![emoji22]
How unlucky can i get i msg n contacted the seller 1hr after the post on fb looks like i have to pick up my gain a bit next time and contact 1min after posting.
[emoji25]
