Specs:
Mobo - Asus ROG Rampage IV Black
CPU - 2011 i7 4930 - @ 4.6
GPU's - 2 x GTX 1080 Hydro Copper
Ram - G.Skill Ripjaw 16gb (4x4) @ 2400
Case: Phanteks Enthoo Primo
Water Cooling :
EK Supremacy Gold CPU Water Block, GPU's stock WB's - Classy HC's
Rads:
1 x EK 480 x 60mm Rad for GPU's - 8 120mm fans Push Pull
1 x EK 240 x 60mm Rad - CPU - 4 120mm Push Pull
2 x D5 Vario Pumps with EK X-Top pump tops
NZXT External touch screen Fan Controller
Hard Drives:
2 x 1TB Samsung Evo840 SSD in raid 0 for OS and games
256GB SSD for Downloads
600gb Velociraptor for general data
PSU - Corsair AX1200i
OS: Windows 10 64 bit
BitFenix Alchemy blue LED lighting 600mm x 3 and 1 white 600mm
Monitor - Asus ROG Swift PG348Q
ASTRO A40 Headset
Logitech G700s Mouse
Logitech G19s
Old pic from when I first built it update pic next week [emoji12]
KeyboardIMG_1483585283.790842.thumb.jpg.c2bcb97b
  • Like 1
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
