3 hours ago, z00key said:
Not sure of the build up, could be from acid rain in japan?
Anyone up for a antilag supercruise in Collie later in the year?
basically $130 for almost all day unlimited use of the track. No drifting or standing burnouts but everything else is fine. next one is May but i can make it. hoping to make august or october
  • Like 1
1 minute ago, TiTAN said:
Have you tried using a razor on the stains/build up? Same way you would tackle bad build up on a glass shower door/partition. Needs to be fresh and sharp.
yep agreed.
thats how i clean the glass on my aquarium when its really dirty
Ok, New Windshield is on, It came pre-tinted which was nice. Looks much better than the last one.  and the Drivers Side door is fixed.
All but he charged me $603, and JapWreck charged me $125 for the window (which was the wrong window and I had to go back and get it swapped).
I played Tetris in my garage, moved a bunch of shit around etc... Now I can *just* barely fit the skyline in *if* I climb out through the passenger door
  • Like 2
Yeah the razor blade was 1 of the 1st things i tried with no change at all. Tried barmans friend, vinegar and baking soda, all sorts of Polish and all thats worked has been mothers water spot remover and a heavy duty buffer. As for track time i have never done it but could be keen.
  • Like 1
take care of it!!
  • Like 1
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
