24 minutes ago, pol1on1 said:
Ok no problem
Is your car the one from down rockingham way? There was a guy selling both his gtrs, one was silver and striped out with a cage, the other was silvwr with a 400r bodykit and -5s under the hood
  • Like 1
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size [emoji7] (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin [emoji24][emoji24]
Will know more after first inspection this week, wish me luck!!
  • Like 2
Morning all!!
You can borrow my rims if they suit, I'll be home Wednesday to discuss further.
  • Like 2
14 minutes ago, shoey85 said:
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size emoji7.png (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin emoji24.pngemoji24.png
If you're willing to do the legwork of removing them and putting them back on you can borrow my rims and guardliners. (R33 and R34 are interchangeable, my front left is an R34). Not sure if rims will pass as the front left is bent (only noticeable at high speeds)
  • Like 2
Morning all!!
Just rock up with my car , I'm sure you will
Pass with flying color ? lol kidding !
Wait service at Honda..... Feel like I'm in Japan again [emoji7]
  • Like 1
2 hours ago, shoey85 said:
Morning all!!
borrow mine just put some new rubber on it for me :P
  • Like 1
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
