I need some advise I am going to get a muffler fitted and maybe a extra one. All that I have on the skyline at the moment is a 3" straight from the turbo to the back. It's too loud. What do you recommend to put in. Also I don't want it too quiet
Can you weld? Do you have a welder?
Edited by R33kizza
I had 3" turbo back with cat and 3" straight through muffler and was fine.
Changed to bigger turbo and it was terribly loud. Replaced muffler to bigger one and fitted 3" resonator inline. It's now bearable but on long drives my kids get headaches in the back. Not loud enough to attract attention unless heavily accelerating/decelerating
  • Like 1
This is what i was gonna say, weld in a resonator and muffler
It's missing a cat too. I can weld but I don't have the tools available here so I'll just take it to the shop. I'll ask them to fit a muffler and a resonator. What brands are you guys running. I don't know if I can be bothered with a cat
Anything would do the job on a budget, u can get a full system on ebay for 300 bucks
Yer I wasn't worried about cost just wanted something to last and something with a nice note.
I ebayed muffler and resonator separately. Then got a shop to put it all together.
Get a metal intake pipe... You won't care about exhaust note when spool sounds heavenly and twice as loud
3 minutes ago, t_revz said:
Agreed, but its convenient for cruise tuning.
I'd rather egt than wideband
True, its hard to find something that is accurate. I find cars that are tuned on dynos can be reli rich and they use wide band. Iv seen cars with on board wide bands show 11 and a dyno centre show 12 doesnt seem like alot but it is
I tried 2 cheap EGT's on my ute that both failed quickly. Got one from an industrial engine used in mining applications.
Apart from being built stronger it reads up to 100C differently
  • Like 1
Cant beat industrial!!!
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
