Mouse hunt at Trevs shed.
Caught 3 and still at least 2 on the loose. Have found by putting music on loud they are oblivious to me being in there.
World's worst mouse catcher.DSC_0212.JPGIf you had pats on the loose in the shed he could round that s### up.
Anyone use Keverk crane on their LV or LT at work ?
Be dam careful with it i learnt the hard way yesterday
No but I've used Kevrek [emoji12]
Glad it wasn't worse mark. That could have done a heap more damage
Yes im glad too.
If it was the 1500 model maybe i would be worse off.
It did crush it and maxed out the motor and i could not pull my hand out lucky i could slip the lever between fingers and with the other hand pull the other way to boom up to release.
Lesson learned won't do that again haha [emoji12]
  • Like 1
Week days are very quiet (atmosphere will be abit meh)....which is quite sad but yeh, hope you enjoy the food =)
Fine with me more of a catch up with an old mate thought we would try out your new diggs in the process [emoji6]
