no.
fuel or ignition, fuel cut is the go to default as its softer. ignition cut gives pops and bangs (and on an RB isnt great for the oil pump) and is harder.
powerfc does fuel cut for the limiter, more advanced computers can do either or both as steps (eg kill fuel at 8k and fuel and ignition at 8.5k)
  • Like 1
no.
Why oil pump dont like it ?
Im thinking of detonation as i did hit 66 knock at 7950rpm pop pop pop.
I have dejetro i have map no AFM
The only one for ign cut in PFC is pfc Pro n it has launch control too.
Im intrested in how launch control is done and how much more its helpfull
Because the oil pump drive off the crank gets smacked around like a hammer as the ignition cut limiters are generally faster to cut/resume and this eventually cracks the gear in your oil pump losing oil pressure followed shortly by the rest of your engine and turbo dying.
Launch control depends on the ecu, some are just a 2ndary limiter, some do ignition retard and add fuel to build boost. If you have a gtst. Launch control that builds boost is fairly pointless as it just results in wheel spin.
Full grip baby GT-R style [emoji12]
Then it makes more sense.
But be aware that it's not nice on your gearbox/clutch/drive shafts. Revving the car up to 4k and dropping the clutch isn't nearly as likely to break things as Revving the car up to 4k, building 20psi and then dropping the clutch.
It's really a show off thing or drag racing thing, other than making turbo noises at the lights or in carparks it has no practical Street use.
4k and full boost yummm.
I attempted learning to do smooth launch 7k drop clutch swiftly.
But still smelt clutch now paranoid about clutch life left.
Anything under 7k i bogged down. May -5 turbos not helping
I hit 300 knock once. 91ron fuel
Good times
Our pumps came with a hex type shape that cracks on the corners and it didn't sit fully on the crank on earlier models so the edges get worn making a loose fit.
I fitted a collar to my crank to rectify but mobs like tomei use a spline instead of the hex
  • Like 1
Good times as in rebuild?
Only 1 piston didn't have broken ring lands when I rebuilt but I'm unsure which incident broke them. It was overheated twice. Knocked to 300 once and ran so retarded once that the exhaust manifold snapped,all studs broke, turbo shaft snapped and engine harness melted
But I rebuilt it 3 years after all of these events so it held up well [emoji12]
Wow that a decent effort.
So did you do a spastic rebuild or a normal one.
Same crank, forged JE pistons, spent a heap on port/polish and modifying the head. Tomei cams,springs,exh gear. New turbo and all the associated supporting bits.
Best case should do about 450hp at treads on 98 or into the mid 500's on e85. Hopefully get it going within a week. Needs a new alarm system
Is it worth the money on the head. Coz that the area i 1st want to mod.
It's not one of the things you need to bother with at the power level -5 will give you. Small duration high lift cams are a better spend (~260 deg ~10mm)
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
