no.
fuel or ignition, fuel cut is the go to default as its softer. ignition cut gives pops and bangs (and on an RB isnt great for the oil pump) and is harder.
powerfc does fuel cut for the limiter, more advanced computers can do either or both as steps (eg kill fuel at 8k and fuel and ignition at 8.5k)
  • Like 1
no.
Why oil pump dont like it ?
Im thinking of detonation as i did hit 66 knock at 7950rpm pop pop pop.
I have dejetro i have map no AFM
The only one for ign cut in PFC is pfc Pro n it has launch control too.
Im intrested in how launch control is done and how much more its helpfull
Because the oil pump drive off the crank gets smacked around like a hammer as the ignition cut limiters are generally faster to cut/resume and this eventually cracks the gear in your oil pump losing oil pressure followed shortly by the rest of your engine and turbo dying.
Launch control depends on the ecu, some are just a 2ndary limiter, some do ignition retard and add fuel to build boost. If you have a gtst. Launch control that builds boost is fairly pointless as it just results in wheel spin.
Full grip baby GT-R style [emoji12]
Then it makes more sense.
But be aware that it's not nice on your gearbox/clutch/drive shafts. Revving the car up to 4k and dropping the clutch isn't nearly as likely to break things as Revving the car up to 4k, building 20psi and then dropping the clutch.
It's really a show off thing or drag racing thing, other than making turbo noises at the lights or in carparks it has no practical Street use.
4k and full boost yummm.
I attempted learning to do smooth launch 7k drop clutch swiftly.
But still smelt clutch now paranoid about clutch life left.
Anything under 7k i bogged down. May -5 turbos not helping
I hit 300 knock once. 91ron fuel
Good times
Our pumps came with a hex type shape that cracks on the corners and it didn't sit fully on the crank on earlier models so the edges get worn making a loose fit.
I fitted a collar to my crank to rectify but mobs like tomei use a spline instead of the hex
  • Like 1
Good times as in rebuild?
Only 1 piston didn't have broken ring lands when I rebuilt but I'm unsure which incident broke them. It was overheated twice. Knocked to 300 once and ran so retarded once that the exhaust manifold snapped,all studs broke, turbo shaft snapped and engine harness melted
But I rebuilt it 3 years after all of these events so it held up well [emoji12]
Wow that a decent effort.
So did you do a spastic rebuild or a normal one.
Same crank, forged JE pistons, spent a heap on port/polish and modifying the head. Tomei cams,springs,exh gear. New turbo and all the associated supporting bits.
Best case should do about 450hp at treads on 98 or into the mid 500's on e85. Hopefully get it going within a week. Needs a new alarm system
Is it worth the money on the head. Coz that the area i 1st want to mod.
It's not one of the things you need to bother with at the power level -5 will give you. Small duration high lift cams are a better spend (~260 deg ~10mm)
  • Like 1
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
