Inlaws are over 1000km away. Have friends nearby but haven’t mentioned it yet
Fair enough :) First week back at work , Busy with works already :(
Kieran , ill Give You a Call sometimes this week to arrange the car drop. Im struggling with time management this week [emoji24][emoji24]
Kieran , ill Give You a Call sometimes this week to arrange the car drop. Im struggling with time management this week emoji24.pngemoji24.png
Il come to ur house and do it if its easyer?
  • Like 1
2 hours ago, shoey85 said:
Morning sweet cheeks! My new pads arrived today emoji1303.pngemoji1319.pngemoji2.png
maxi or regular?
In other news, woke up this morning, rolled over to face The Good Wife who, while still sound assleep. said to me very clearly
"If you try and replace me as your wife again, I will definately kill you"
:unsure:
  • Like 3
  • Confused 1
1 hour ago, Stinky Rooster said:
maxi or regular?
:unsure:
in which u replied " not to replace, i just want 2 for when the main one is broken or out of service for a week"
yeeeeeeeeah I kinda like my genitals in-situ kthnx
besides, you would have to be absofknlutely tapped in the head to want more than 1 wife
like, mormon stylez tapped in the head
and nobody wants to go that far
  • Like 1
6 hours ago, Stinky Rooster said:
besides, you uld have to be absofknlutely tapped in the head to want more than 1 wife
Your bang on there!
Sanae once asked me what i would do if something happened to her...would i re-marry etc
i said FARK THAT!! ill be able to go fishing whenever i want without getting hassled. why would i give that up twice in my life?
  • Like 2
Your bang on there!
I’m with you ! Not about fishing tho , something else [emoji28]
  • Like 1
Louis Vuitton? Haha
Hahahaha nah ! Not a big fan .
Just watched MCM Trip to Suzuka , they bought Nissan Fairlady Z ( early 70’s) model
And took them to the race track [emoji28] $50 per hour to hire the track , wonder how much they pay that car in Japan , in here perth selling for $55k and above !
  • Like 1
well, that was a bit of a shit start to the day - stuck in a lift for over an hour.
On the upside, was stuck in there with an ex Sarich engineer, and am now fully up to spec on the history of the Orbital Engine Co., and what a fkn story!!
  • Like 2
So you know why they got shutdown then?
apparently when they changed out to the injection system for 2 strokes (from the orbital engine program) they ran in to massive issues of deposits on the injectors, caused mostly by fuel and oil purity issues, and Ford Cologne (who had been backing them until that point) pulled the plug. The company tried to go out on its own, and even produced 85 ford festivas with the system fitted, which they basically gave away on the agreement they got them back to assess after a given time, but due to the completely nonexistent support for the company, the ideas or even the chance for a full manufacturing setup here in Perth
(Tickford actually DID build a production line in Balcatta that built the first 85 cars)
It died a sad death, killed off by apathy, lack of foresight and a shit government that missed a golden opportunity to put Australia at the forefront of automotive engineering for decades to come. And if anyone thinks it was a unacheivable pipe dream, just remember that this country is full of people who have massively changed the automotive game. Blokes like Rod Hatfield, and Jim Read to name a few.
And now I am depressed and angry at mah counrty :(
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
