Here are some pics. . .
You should really see the video of my reaction when I first saw the car =D
Bought some ze40's  Got a weird size though. . . 17x8.5 +30 i think. . .
Then after getting Anonymouse  post bought a spare set of SSR type C (I reckon they fkn hot. . .)
18x9.5+15. Bought in Japan.. they gay gold colour will get them blasted painted probably gun metal + new stickers. .
Spent nights and nights researching wheels. . mainly weights. . these 2 are super light weight.
There is lighter but they dont look as sick as these. . Buddy club almost impossible to find. . Oz racing wanted some stupid price like $3,800 for the last set in aus. pfft. .  just got Rays ze's
Burning the credit card on car gear lol. all part of the fun..
Still havent taken it for a (proper) drive yet. . . =/ only to get paper work for licence application.
So its not really driving. .  no plates on the car so felt like a criminal. . and now i have the plates so..
Just need to chop or bend them to fit though.
  • Like 3
Umm. . . Been thinking about it. . . not sure. . need to look into it more. .
Its all personal preference. . Think id feel little weird with custom. want to remain random. . like not stand out. . might change my mind. . .
eg. know a guy with a supra who took to speedway. Reckons he did under 10sec. (whether this is true doesn't really matter)
Supposedly because the car is that fast cant bring it back unless he has a roll cage. .(i don't know if this is all true).
But he had custom plates and reckons he gets pulled over alot. . . .
  • Like 1
I'm 10 min from the Perth city.
If i'm invited ill come. Keen as mustard =D
Think will be easier small cruise. last one of 40+ ppl would be little off putting. (not easy to manage)
But yeah, just catch up with cars have chat. if all things go well have a meal or drive or what-ever. =D
  • Like 2
5acb5aed4803b_volkracingze40mattebluegunmetal1.jpg.05f45fdf86d7b14d1799fc71a62ee74d.jpg
Wow dude she's a beast. Scaring v8's and cosworths Australia wide. Vspec2. [emoji41][emoji122]. Godzilla. We've got a zookey here somewhere?
  • Like 2
Of course you are [emoji28] cool
I’ll ask around and will update you all soon x
  • Like 2
Yeah they need to bend like 20mm each end to fit in front bumber. . stupidly large Aus plates =/
Either cut or bend. . dont know what cops would think. . . . but considering only been pulled over once in 15 years driving. . .
this is different car though =/
been looking at custom plates but NFI what to get. . . blegh gonna sit on fence for this one.
Bend them. Never cut plates as you can always unbend them if you need to, if they are cut you have to fork out for replacement plates if you get done for it.
  • Like 2
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
