On ‎20‎/‎06‎/‎2018 at 1:14 PM, Hank Scorpio said:
You're awful, you really should.
Noted.
Any chance the Big Rev Trev and The Red Bearded Lurker roadshow will be heading back to civilization any time soon?
Just now, Stinky Rooster said:
Noted.
I think Trev said he was heading up again in the not too distant future.
The Lurker's better half is about to pop, so good luck there!
3 hours ago, t_revz said:
August I believe...then late October if I’m not mistaken
Gimme a date in August and I will host a bbq that will leave you all pre-diabetic. I have a pork candy recipe that will make it all worthwhile :P
As for the Lurkers current misfortune, I always say its the womans fault for taking seriously something that was poked at her in fun.
  • Like 1
Gimme a date in August and I will host a bbq that will leave you all pre-diabetic. I have a pork candy recipe that will make it all worthwhile [emoji14]
Between work, work and more work, I’m surprised he found the time
I reckon at their wedding ceremony he would have tried to slip a 5/8 ring spanner on her finger
Pork belly burnt ends ftw!
I did some killer spare ribs last night, no pictures tho, just demolished! (Bourbon BBQ sauce glaze of course!)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
