Dale.
I'm doing an order from Troy's Meats if you want anything - https://www.facebook.com/troysmeats/posts/706363436366223
Getting Hank some lambs necks, come in packs of 2 and they're full necks, not the little cut up rosettes, so awesome to keep the doggo interested for a while ("soft" bone as well).
Cant see FB at work, so link is no good, but you reckon you could grab an extra 2 packs of the necks for me? I will get Blossom's opinion of the secret butcher first before I go buck wild. OK if I fix you up for them on Sunday?
I had Cape Grim for the first time a few weeks ago, and would def recommend. Pretty sure he stocks the grass fed stuff
On ‎7‎/‎17‎/‎2018 at 8:37 PM, pol1on1 said:
Yer oil dipstick popped out too much pressure in crankcase.
Not sure to why i had so much pressure to do that. But to fix the problem and do happy track dayz i think i need a catch can, larger sump, baffle kit for sump n cam cover, oil restrictor Maybe even a oil accumulator on top.
Then it might hit the track again but for now ill keep it straight drag pass.
Did loose about 4ltrs of oil from 6 hardly touching the dipstick that how known something went wrong as i was going up the shecane at 6k to 8k rpm i look down n noticed oil pressure at 2kgcm2..... at that point my car seat had me by the balls.
No knocking but at idle in gear lift the clutch put load on engine makes a small squeaking sound n crank pully has very slight movement . So thrust bearing has worn too much. :(
Not fun.  The root cause of it all is blowby.  Around Wanneroo RB's should be fine.  Before you chuck any bandaids on it check the compression.  Also as has been said check the remaining oil for go fast glitter.
  • Like 1
Yup
So, I learned a thing today
Turns out there is a sentence terminator called an Interobang, and its actually recognized by Websters as a valid way to end a sentence, and is usually to infer either a rhetorical question, or a question used as a statement.
Actual composition is a combination of the question mark and the exclamation mark.
Unicode for it is U+203D for any fellow word nuts that want to give it a crack
  • Like 1
11 minutes ago, Stinky Rooster said:
Yup
Cool
  • Like 1
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
