23 hours ago, Hank Scorpio said:
Ordered a box of jamwood and a box of cherry from your mates at Flavourwood last night.
Going to be a big weekend of dessert, as the mrs has an order from the blokes at my work for a massive cake, and I will be doing my dessert entry.
My back patio is going to smell amazeballs
  • Like 1
Yeah I used to make it.
First tip - don't trust any yeast that comes in a package with wort etc. Every time I did, I would get bugger all fizz in the bottle. Swapped it out for a behind the counter yeast from my local brew store and before I knew it, I had bottles exploding regularly :D
Also - if you end up with an alcohol content above 10%, its best NOT to mix it with dark rum, no matter how much of a good idea it sounds...
Lastly - buy a bottle washer. Trust me on this
Sounds awesome! *drools*
What could possibly go wrong?
niiiiiiiiiiiiiiice
Well, 12 hours into my first ever 24 hour sous vide adventure, and the meat looks exactly the same  O_O
so if I kill myself with food poisoning tonight, I want it on public record that the dog gets my playstation 4
1 hour ago, Stinky Rooster said:
niiiiiiiiiiiiiiice
You'll be fine.
Are you reverse searing or?
4 hours ago, Stinky Rooster said:
That's the plan, but I will probably just use a skillet, as firing up the kettle for a 3-5 minute love in with Maillard seems like overkill
I'd do the former for sure.
holy shit they were amazing. The Good Wife put together a reduction from the bag juices and we smashed them so fast I forgot to take a pic :(
They held together in the skillet really well, but soooooooooo fkn tender and juicy
sous vide is officially win
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
