What are you riding?
I didn't even know you had a dirt bike. :D Imma be down your way on mine this coming weekend. You ever ride Collie? I has some epic "unfit old man" trails around them parts
Oh jeebuz, one of them.....
I have personally seen 3 of them die mid ride now. Last one was my boss, he cooked the engine 50km from anywhere, and the only good thing about it, was pulling him out of there on the back of the bike he had relentlessly pulled the piss out of for 6 solid months. Keep a close eye on your service times,  but I have heard that slow trail riding has killed more 300exc's than thrashing the guts out of them. Its the heat build up in the clutch apparently
I did notice that on the weekend. It got a tad warm and was getting hard to start. all the other boys have 350's so i am thinking of going to one also (mmm electric start).
Or just get a mans bike 500cc [emoji1305] I used to have a Husaberg fe550e then got the fe501 which was basically a KTM 6 days, yeah my bro was envious with his exc500 IMG_2515.PNG
1 hour ago, turboedsloth said:
After only just getting back on a bike after a few years, i'll take baby steps.
and yet you chose a 300cc 2 stroke... O_O
the last 300exc I rode was WAY more savage than mine. Was a lot more fun on the back wheel too.
Main difference I could pick, was how much more comfy a big bike is at road speed. Watching the boss in the mirrors at 80kph was a show that should have come with a dinner
A whole weekend of meat, charcoal and motorsports. I am like a kid at xmas with his first stiffy!!!!
Oh, and 500 odd km on my bike!!
the weekend starts NAOW!!!
  • Like 1
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
