wait, what?
Is there a junior red bearded lurker in the wings?
You’ll have to wait another month before he returns and confirms.
I think he has had enough practice time. Jade probably thinks this will get him to go home once in a while
  • Like 2
oh lawd
turns out "bring your kids to work day" doesn't really work when you are counting on engineers telling them what they do, to be enough entertainment and stimulation for kids. My normally quiet office currently sounds like a day care centre that has been accidentally hosed down with red cordial and dexxies.....
damn breeders.......
You should have brought yours in too.
I did consider that, get 'em married off to a couple of graduate engineers, cash in on a dowry etc, but the risk of triggering a wave of maternal instinct with all the loinspawn about the place was too risky.
  • Like 1
Born in starter cap with Nike's on ;-)
oh lawd
Should have let them loose on the oxy and plasma cutter. You touch this while I push the button. :-o
On 1/20/2018 at 7:12 PM, Stinky Rooster said:
congrats to you and Jade
my prediction -
5707ffab2e00002d00950cb8.jpeg?ops=scalef
Strong resemblance is strong:4_joy:
And thanks mang. She's pretty excited. Her mum has gone fricking nuts buying stuff already
  • Like 2
2 hours ago, turboedsloth said:
...... gone fricking nuts buying stuff already
Look on the bright side mate - that only last for the first 18 -20 years.
:D
@shoey85 hows the holiday planning coming along? im getting a bit excited. going to see this week whats involved at making rig n van wheels interchangeable or atleast fit if it all goes pear shaped.
still havent 100% planned destinations, but have a few places that are must sees
  • Like 1
[mention=143902]shoey85[/mention] hows the holiday planning coming along? im getting a bit excited. going to see this week whats involved at making rig n van wheels interchangeable or atleast fit if it all goes pear shaped.
We were just discussing it lol, like you no plans just ideas so far and places I want to see like wolf creek crater, Mitchell falls, hot springs, Emma gorge, karrijini and so much more.
Bought most of my electronics like the brake controller, harness and dual battery last week, big job for me this weekend!!
Still loads of stuff to buy, fridge or 2, spotties, snorkel, diff breathers and the list goes on and on.
Now I just need my crypto to triple in price and I’m set!
  • Like 2
Ours is easy-ish to setup (10 mins max) but the awning is painful.
10 to setup and 15 to pack up and it sometimes won’t fit back in pouch properly. If I can’t modify easily then I’ll get another before going.
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
