Why not just buy a known working engine and save yourself the headache. They're cheap enough.
Look up rods and pistons then add in you may be up for a crank also depending on how bad the damage is. Add on the cost of machining and assembly. For allllll of that you could buy two (possibly more) working stockers.
  • Like 1
solved that misconception then.
its the same as asking how much for a respray.
depends whats broken, what issues arrise when you start, how far do you want or need to go, what parts your using, how much your paying per hour, how long it takes.
Its not hard asking people to help you.
They also don't have to help you.
Take charge of your life and do things for yourself. You will gain knowledge and a fulfilling sense of achievement.
It will set a good example for those around you.
  • Like 3
I didn't actually think it would be this hard just to jump online and ask if anyone had done this before and find out an approximate cost...
My bill was $3000. That included machining and the cost to screw it together.
That DID NOT include oil pump, water pump, set of pistons, head gasket or any of the other parts you may change.
Buying something "cheap" because it's busted only to spend what you saved plus much more doesn't seem a good plan.
  • Like 1
To fully rebuild an engine and make it stronger with forged pistons rods etc.
Got quoted about 10k from race pace - Their quality of work is top notch tho
Its all depends on how much you want to spend.
IMO, Its better to just buy a second hand engine, but I prefer to rebuild it so it lasts and I have no future headaches -
Appears there are so many arrogant pricks on this forum, be alot easier to just answer the kids genuine question
Edited by MariahCarey
  • Like 1
I would have to agree the guy only asked an approx cost. Few ego problems
Good on you piggaz :)
Because we all have different engine builders
I paid 7k for a build that had nothing but issues before it went bang
could easily pay 20k + to get something half decent and that doesnt include things like turbos and manifolds
For a R33 Rb25det, it really needs the pistons and valve springs, its a good idea to have it properly built then saving coins. Mine cost about $5G to rebuild including CP pistons, Supertech valve springs plus other bits and pieces.
Well - I ended up cracking my block.
bending my crank
putting metal through my turbos
blowing up my oil pump
putting metal through oil cooler.
cleaning head
machining head
checking new block
getting new bearings
pistons
rods
head gasket
valve springs retainers and guides
new oil pump etc etc
So its cost over $20k.
So lets say a basic build could be $5k. Full forged build with heaps the goodies and pretty much worst case engine damage.....$20k
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
