1x R33 APEXi Power FC (model serial no: PFC ECR33 010-1098)
1x APEXi Power FC hand controller (model serial no: FCC3 020-08934)
1x GReddy PRofec B-spec II (complete with wiring harnesses and solenoid)
Removed from a running 1995 R33 GTST Series 1.5 RB25DET to upgrade to a Haltech ECU.
The ECU came with the car when I bought it three and a half years ago. I bought and installed the PRofec B at that time. I had it all re-tuned in May 2012 when I installed 850cc Denso injectors and a GCG Hi-Flowed R34 turbo. That setup made 260 rwkw on pump 98 at 18-19 psi, we maxed out the stock valve springs as they were noisy with any more boost.
I've upgraded to a Haltech Platinum Pro Plug-In ECU with built in boost control so I have no need for these.
The tune currently on it is for stock R33 GTST RB25, stock (pink label) MAF, 850cc Denso injectors, front mount return flow intercooler and GCG hi-flowed turbo. Plus fuel pump and other supporting mods of course.
As the package does include the hand controller it is possible to reset the ECU back to factory settings to plug into a car that is stock as a rock and have it work on a base tune. It's unlikely that you have the same mods as I did to be able to use the tune it has now, mainly the 850cc injectors etc.
Price: $1,150
Where: McDowall, QLD
How: Pickup preferred but will post at buyers expense.
Contact: PM or mobile 0 4 0 2 2 3 2 5 5 6 or email brettd at qubitonline dot com
Any questions feel free to ask in this thread.
I have a couple of people interested in just the ECU and hand controller so if that happens I'll hit you guys up about the boost controller.
Look like the Power FC and hand controller is sold, getting picked up today so $200 plus post for the Profec B boost controller.
Sold to me :)
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
