Hi Everyone,
I am currently looking at purchasing an EBC, but am unsure on which one is better. The two I have been looking at are the GFB GeForce II and the Turbosmart Eboost2. Both are relatively cheap, which is what I am after. But just wonder if anyone has one of these and has any advice/tips about either.
From my own research they seem to do the exact same thing, but the GFB one is fair bit cheaper, and I like how it will display the peak boost after for a short time
Also may be a stupid question, but i have a normal boost gauge on my A pillar at the moment, would the eboost be a simple swap in for it or would there be more wires/pipes needed? or will it even fit in the pillar?
Sorry for the noobish question, only still pretty new to forced induction.
Thanks in advance :)
I have used both that you mentioned and prefer the GFB unit. But it's a personal thing. Performance is identical
Both are awkward to mount in the cabin but the GFB has a nicer display so you can delete a boost gauge. Although the led lighting stands out if you get pulled over, it just might draw attention more than the eboost.
In conclusion: toss a coin
I used the gfb unit on my 180 and it was great, easy to use touch screen handled boost up to 50psi and very stable, could change colour to suit cabin gauges and the best thing is that it had an over boost function that cuts all boost at a pre set level so to prevent any spikes. Got mine for $300 a lot cheaper than others on the market, would defiantly buy again!
  • 4 years later...
The tuner I spoke to seems to think the eboost2 is better since you can set boost by rpm, so if you have a small turbo that’s dropping boost higher in the rev range you can set the boost higher as the revs climb.
He seems to the the GFB controller doesn’t have this function.
I see it it does have sensitivity, but apparently it’s not the same. Is that true and the eboost2 is better?
I do find with my Gforce it will peak at about 9 or 10psi then drop back to 7psi even though the target is 9psi but I think the turbo will run up to about 18psi
If I had to pick, I'll get the GFB as it's piss easy to use. Plus you can change the colour of the controller to suit your interior.
I've used an eBoost once and didn't find it very intuitive. At the end of the day, these things do the same thing with the same type of solenoid, yes the eBoost will allow you to boost by RPM however does your car/setup even need it?
So save your money, get the GFB and spend the change on your missus.
These days I would expect most ECUs do at least as good a job, have the ability to set other rules to decide how to manage boost control, and various inputs can be used if "on the fly" adjustments are needed - so really I'd not bother with any of them, or upgrade engine management and profit from having generally much better all kinds of stuff as a result.
I believe he is running a PowerFC - so running this on a near stock setup provides much better value for money.
Side note, the amount of people who splash out on EVC5/6 and don't bother connecting up vehicle speed and RPM input but yet insist on getting the best EBC because it controls boost well.
Oh yeah, for sure... for the OP that definitely makes sense - but given the original question was asked 4 years ago so I was talking more generally :)
Sorry was referring to Ben's more recent question about the EBCs which was asked on Thursday.
OP probably had Microtech with pots you adjusted with a flat head screw driver using visual cues to determine AFRs.
  • 3 weeks later...
Thanks all, will stick with the gforce 2 then.
Strange though, if I bring it on boost from say 2000 rpm in 4th I’ll get about 6psi from about 2000rpm, but it will stay there and slowly increase to about 8 or 9psi around 5000rpm.
Alternatively if I go full throttle in 1st gear I’ll get around 12.5psi around 5000rpm.
Its just strange that the boost isn’t that consistent? I would have thought with this small turbo, it should have been closer to the 12 psi mark from about 3k easy.
I’m thinking of trying out my old turbotech to see if that’s better?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
