Hey guys,
Recently finished my build and have only clocked about 1,000kms on the new motor.
Having a small issue which has had me baffled for a few weeks now.
My oil pressure light stays on when I start the car and is very lazy to build pressure. I think (on a cold morning) it takes upto 2 seconds for oil pressure to build up. I can also confirm that I hear the hydraulic lifters tapping loudly until the light turns off.
Once the car is on, my oil pressure is fine. Starts off nice and high and reduces to a good level as the oil warms up.
So to clarify, I have absolutely no oil pressure issues once the car is on and I'm driving.
I've tried researching a lot and can't find any decent leads - I'd greatly appreciate if you guys could provide me with some advice on how to resolve this issue!
I'm desperate for help as I'm leaning towards buying an oil accumulator to resolve this issue - i just don't want to blanket cover a deeper problem.
Cheers guys!
https://www.sau.com.au/forums/topic/457179-rb3025-start-up-oil-pressure-issues/
what oil you using?
what mods done to engine?
any oil cooler or additional things in oiling system?
what guage?
Oil: royal purple 10w:40
Mods to engine: 40 thou forged Pistons and rods, crank with extended crank collar, n1 oil pump with standard gears, standard oil sump + pickup, cancelled VCT and grub screwed the feed.
Additions to oil system: none at the moment - only thing I did was fit the stock rb25 oil cooler thing to the rb30. Not using an aftermarket oil pressure gauge... Using the shitty stock one at the moment.
I know the stock gauge is inaccurate, but I know the light is accurate because once it turns off, the tappet noises quieten down.
Your oil and filter choice is fine. But the pressure not building up instantly on start up is a problem. You shouldn't be seeing a delay in pressure build up and the light should not come on.
There is definitely some underlying problem and the tappet noise could well be related to it.
Is there anything you may have skimmed over in the build (if you did it yourself) accidentally or some kind of blockage/restriction?
Might want to check the oil cooler is not getting restricted, causing that slight delay in pressure build up.
what is the hot oil pressure reading? your not going to know this with OEM shitty gauge... get yourself an aftermarket one and sus it out. If over all pressure is low or it drops when hot then i'd dare say your bearing clearances are up shit creek
I built it myself with a mechanic over watching what I did. I don't recall missing anything and I'm not having any blowby issues.
Need an aftermarket gauge to tell you the exact pressure, but my oem gauge has similar readings to what I used to have before the rebuild. It seems as though issue is solely on startup but I do plan on getting a mechanical gauge thrown in to test...
Filter drainback valve thingo.
I already tested for that issue. I turned the car off and let it sit for a day and then unscrewed my oil filter and it was still full of oil. Unfortunately that's not my issue :(
The grub screwed vct oil feed- would this have an affect?
Research has shown me that everybody does this so I didn't even think about it. The grub screw is in the head though, so would it effect oil pressure at the sender unit in the block?
    • Robertson was a Canadian inventor, and it absolutely reigns supreme here. 95% of our screws are Roberston. It's literally the only option you can buy off store shelves. What would it have lost out too? I believe it's also very popular in the US.  My reference to imperial was pointed to both NPT and BSP.
    • No. BSP lost to the cultural/technical imperialism of living next to Trumpistan. Face it, Robertson screws were better and still pretty much lost out to the yank stuff. The Europeans hate the Brits and they don't use NPT. NPT is just as "imperial" as BSP is, being based on those useless inch thingos. Just done differently.
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
