Ok so my r32 is been getting tuned for the last 3 weeks now got a cool to day same it only made 130kw something do add up here.
It got haltech Ecu 440cc injectors gt25/30 full 3- 3 1/2 exhaust fmic spitfire coil pack big fuel pump fuel reg.
something don't add up that was 15psi.
Any one else had a shit tune done
https://www.sau.com.au/forums/topic/457362-r32-gtst-dyno-results/
My r32 has been getting tuned for the last 3 weeks. I got a call today saying it only made 130kw. Something doesn't add up here.
It has got a haltech Ecu, 440cc injectors, gt25/30, full 3- 3 1/2 exhaust, flick, spitfire coil packs, big fuel pump fuel reg. Etc.
Something thing doesn't add up. That was 15psi.
Has anyone else had a shit tune done?
  • Like 1
^^ lol thanks for the english translation Ben :)
I'm sure in the history of skylines people have had a shit tune done before. But the motor may have other issues. What was the motor taking in terms of ignition timing at peak torque? post the dyno sheet as well.
What did the tuner say? Is he experienced with Haltechs? Yes, 130rwkw is even less than a stock skyline makes. Something's wrong, if the tuner couldn't point a finger at something find another tuner. He should have given you feedback on why he thinks it's so low.
  • Like 1
That's funny because my r32 is been getting tuned for the last 3 weeks now got a cool to day same it only made 130kw something do add up here.
so I rang him yesterday and he told me that it is restricted some were and it's not cooling right. And then tell me he had tuned the boost up to 24 psi to see what it had I was lucky the head gasket didn't pop. So now all I now high boost is 18 psi at 180 something kw which is still pretty shit numbers for 18 psi I think. He then sends me a pic of the fuel leaking out of were then sender goes in he didn't want to fix it. For $20 o ring and 5mis and a pic of the exhaust manifold glow hot
I don't think he know what he is doing on rb and haltech
Edited by Fat533
15psi has a restriction AND not cooling right so lets try almost double the boost... pointless. diminishing returns. risking motor damage. what a genius.
find a haltech/RB expert.
trolling
not necessary :down:
He said the exhaust manifold was restricting it and that its get red hot and that's all he told me bout cooling.
There is no cat just straight throw to muff that's it. I don't see how to would change all I did was put new motor in that's it. was running fine when I took it there just a bit on the lean side
it's not the exhaust manifold. RB20 and RB25 exhaust manifolds are identical, and on RB25s they flow 300rwkw without any problems. So it's absolutely impossible that it's causing a problem at 130rwkw!
If it's glowing red hot then it points to the timing being too retarded. retarded timing explains both the low power and the hot exhaust manifold.
question is why is it retarded, either it is knock limited or there is a restriction somewhere although it sounds like it's not the exhaust. if it was running lean then richening it up should have been the first thing he did.
silly question but you are running 98RON fuel right?
I had a mate with a 180sx that suddenly lost power. You could also rev it and have flames come out the exhaust just by pumping the throttle at about 2500rpm. It turned out that the exhaust cam was snapped (but still holding together, just twisted a bit) and so the ignition timing was out relative to the cam.
I'd check the cam timing, as well as making sure the cam sensor is working.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
