Hi Guys,
I went to remove the crossmember bolt for my car tonight so I could change the transmission mount. I realised that some fool had already removed the crossmember before and threaded one of the bolts. I got the threaded bolt but the nut part which the bolt threads into is stripped also.
I managed to get a bolt to thread into it but it's not super tight - What are my options to sort this out? I've heard about helicoils but I have no idea about these.
Thanks
https://www.sau.com.au/forums/topic/457401-threaded-crossmember-bolt/
You can buy thread repair kits and then fix the stripped thread that way. Most bolt shops should be able to supply them.
It's pretty straight forward but should read up on google on whats involved and how it works before going ahead and doing it.
If you can't tap the next size up bolt thread, a Helicoil is your best bet. The sets aren't cheap though, best to find someone that has the correct size already.
A mobile thread repair bloke will be quickest, but they charge. If you had your location someone local may be able to help.
It will most likely be a fine metric thread. Most tap and die sets only run standard metric threads. Better to buy a single, high quality tap than a generic T&D kit from super cheap. Any kit under $200 won't be very high quality, and I find that the threads are usually oversize (50% thread or worse).
I've made the mistake of running a die nut over a thread I've cut on a lathe to clean the thread. The thread was cut to exacting specs (better than 70%) and the die nut cut way too much out of it, leaving it too loose for the application (high pressure fitting). Live and learn.
Yeah there are plenty of ways to f**k up a thread repair....I'd be taking Scotty's advice and getting a mobile thread guy in. They might cost you a hundred bucks but if you don't deal with this all the time you're likely to stuff it further, and end up with a bunch of expensive tools you'll never leave again.
And yes they are M8 fine which you wont find in most tap kits
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
